Results 1 to 4 of 4
Thread: Power window goes down but not up
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    Default Power window goes down but not up
    my window goes down but not up why does my window do this??
    if i reverse the polarity of the plug in the door the window will go up but not down so the motor is ok.
    is this a switch issue or is it an issue with the relay module
    im not admiring your car im looking in disgust
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Dead electric window switch, i had the same problem with my calais and it was the switch. By reversing the switch you eliminate faulty motor and wiring loom which only leaves the switch to be dead!
    manual VN aero
    May 2005
    SA
    it could be the relay module as i was reversing the polarity at the regulator itself
    i pulled the module apart and everything looks good except for the back of the pcb some of the solder joins look burnt but they still have condinuity
    heres a picture of what i mean
    Attached Thumbnails Attached Thumbnails Power window goes down but not up-burn1.jpg
    Jun 2005
    Ok, sorry i thought you were reversing the polarity at the switch. Try reversing the polarity at the switch, this will tell you if it is the switch or in the module & wiring area. If it is not the switch check the wiring where it goes through the door shell to the pillar as the wiring breaks in there from the door opening & closing all the time.
  1. Power Window Kit for VX
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2010, 11:12 AM
  2. power window problem
    By sircruisealotVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2009, 07:43 AM
  3. vn-vs power window kit
    By winton in forum Parts And Other Items For Sale
    Last Post: 09-12-2007, 11:14 PM
  4. help! power Window goes down but not up
    By vncalais01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2007, 02:10 PM
  5. power window
    By snotta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2005, 10:55 PM
