hey guys, a few days ago i painted my fuel rails and put it all back in, i didnt buy new seals or anything tho, they looked fine, and i cleaned out my tb and the bend, and they seemed fine too, and yesty i noticed i was alittle low on oil so i topped that up this morning. but now wen i start the engine will be at about 800 rpm then drop too about 500 - 400 rpm almost dying then slowly go back up, or it will try and start and just turn over forabit and fire up but unless i put abit of throttle in it will die (happened twice now).
ive also noticed a rattle i thought it was my trany but id say its just a rock sitting on my exaust or something like that, i hope.
so any ideas what it could be causing it to start like that???
when i start mine it is hard and a lot of the time starts when i turn starermotor off?? then sound like its going to die for 5-10sec and unless i give it a bit of throttle it does. alwase starts tho so never bothered me. i thought it may be the distributer (probably timing) coz mine is a s 1 and apparently the go often but i'll leave it till it is completley dead. i am likley wrong tho so othere opinions will help me to.
vn 88, checkall the vacume lines, also check map sensor tube and the 2 switchs hanging off throttle body, also check for petrol leaks, do a diognostics then reset ecu
fixed it, it was either of 2 things, idle air thingy with the 2 hex screws(just took it off and cleaned it) also last time i took it off i adjusted the idle screw, so i wound it back, good as new now
