I have a VN V8 that's a bitch to start when hot. Slow to crank over but it eventually fires most of the time. Wondering if just replacing the battery is going to fix it or if I should be looking for something else (Battery is a few years old) Never touched the starter in the whole time I've had the car. Had injectors serviced and cleaned about 12 months ago.
Any thoughts would be great.
Al
"Everything is legal until you get caught"
yeah Holden starters to get hot! I've had mine recon' and she's still not happy when hot (and my engine bay does get HOT). I'd go the rebuild (esp if you plan on keeping her long term) and have a good look at the wiring too. When she's hot - borrow a mates battery (that you KNOW is charged) and give it a burl.Originally Posted by Alspos
Do the free stuff first - sometimes it's simple stuff
I'd almost garuntee its a rooted coil. 5L's are prone to it, and it sounds like exactly what my car was doing when mine was screwed. If not that, it could even be the ignition module, same deal, 5L's prone to having them fark up.
Originally Posted by davway
Yeah, someone on here posted a fix for the 5L taking longer to crank over, replace the ignition relay.
- 1st JC Cruise, Voted Most Stock Car -
get the car checked over by an electricion before you go spending money on it, its worth them seeing!! maybe it has to do with wiring or the Crank sensor in your car , a DYNO test should show whats wrong with it,,,, it worked for me , my crank angle sensor was failing and when hot would not start, eventually it got worse and stopped and would start the next day.........
Shillanda
not sure the v8's had a crank angle sensor, as they use a distributer...
hey alspos
I'm not sure i'm only 16 but would it be the coil. because my mums old car had the choclit block distrbutor and it used to make the whole car cut out until the engine cooled down and once it cooled down it could turn over without any trouble. so i'm proberly wrong. but all i did was change to the circle lookin one and then i've never had any other trouble so.
i'm wrong arnt i
I HATE RICEZS![]()
i got a VN 5L and it done the same thing, i replaced the battery and terminals changed the relay done nothin... the starter motor was floged out and when its hot would bearly turn over. try a new starter and new leads to the starter. it should solve the problem
Replace the battery in your remote control. Once the battery degrades it doesn't disable the immobiliser completely which doesn't provide the correct voltage to the starter motor when the engine is hot. I presume that your cold starts are OK?
Yeah, cold starts are ok, takes a little while to fire but always does. I don't think it's the remote battery cos even if you leave the keys in and on accessories (so the imobiliser won't come on) it still does it.
Al
Damo was closest.
Replaced the battery with a 550CCA jobbie and cleaned battery terminals. Got under and undid the main cable from the starter and cleaned it and terminal on the starter. Now there's a fun job!! Also the black cover on the solenoid was loose, I'm sure that couldn't have been helping, letting in all sorts of crap. Cleaned and did up tight. All seems good now. Thanks
Al
great stuff! Always worth going the cheap option firstOriginally Posted by Alspos
did ya put oil in your car? sounds like you might need a top up..
