Page 1 of 3 123 LastLast
Results 1 to 25 of 64
Thread: bloody VR engine in my VP
    VP Exec,honda civic,mazda626
    Jan 2006
    watsonia
    Angry bloody VR engine in my VP
    ok had my engine out today and the guy whos doing it has just informed me that the engine in there is off a bloody VR now i didnt buy a VP just to have a VR engine in it i was planning to rebuild a VP engine what the hell is the difference in those engines and am i correct in saying that a VP engine has more power whats the deal? can someone please shed some light on this matter
    VE Berlina International II
    Nov 2003
    The VR engine would ahve more power as it is a newer engine, did youknow that it had a new engine put in it?, coudl be a good thing for you as parts would be more readily avalible plus might have gotten a better bargin than you thought?
    Thats all right, thats ok, I drive a commodore anyway!!!!
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Mate the VP motor would be quicker than the VR.........
    And VP/VR motor's are the exact same imo......
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Jan 2006
    watsonia
    nah didnt know about the engine being in there i ve bloody been ripped i think vr might have more power but vp engine is better more torque should i rebuild the vr engine instead
    Jan 2006
    watsonia
    premmy186 Guest
    thought the vrs had those ecotech bastard engines? i heard they went a bit harder but whos to say unless you dyno both stock engines after 15 years of wear n tear.
    Jan 2006
    watsonia
    the engine that come out which was a vr doesnt look ecotech do they look similar how can i really know if it is a vr engine can i tell holden my engine no
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    vs is ecotech.
    MaT
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    there's stuff all difference man, i dont understand why your havin a cry.
    (no offence, but its hardly the end of the world)
    and just to clear everything up (and show how indifferent the two motors are)
    a vp has 127kw@4800rpm and 293Nm@3600rpm
    a vr has 130kw@4800rpm and 295Nm@3200rpm
    Jan 2006
    watsonia
    ok and what about the bloody weight then eh and if you actually read i was paying for a vp and got ripped thats my beef
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    umm, ok, still dont see why you're worried, unless you wanted all original, theyre pretty close engines, not enough difference to complain about. and both engines should weigh the same, if anything a kg or 2 different.
    Pretender's Avatar
    Pretender is offline Brain function fading .
    Pajero LWB Wagon, Power/economy what's that ???
    Oct 2005
    Sunny Rockingham WA
    If you are referring to the weight of the motor, they are the same motor basically so should not be any different.
    How exactly do you think you got ripped? Newer motor in older car, I'd be happy.
    Never
    $50.00 paid for each answer to a post of mine.
    Please note cheques will not be honoured
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    chill man...damn.
    my reading skills are just fine....how are yours?
    THERE'S NO DIFFERENCE BETWEEN THE ENGINES...INCLUDING THE WEIGHT.
    the only reason a vr is ever so slightly heavier than a vp is from the differences in the body,not anything to do with the engine.
    if anything, you probably got more than what you thought you were paying for with it being a newer engine.
    premmy186 Guest
    just do it up if it goes hard then its gotta be good. im just curious why who ever origanally owned the car would swap the vp for a vr engine. doesn't make much sense?
  15. #15
    1991 VN Commodore, 1997 VS Statesman II V8
    Jun 2005
    Quote Originally Posted by sircruisealotVS
    The VN 88 to 90 was 127kw (according to holden)
    The VN 91 to VR was 130Kw
  16. #16
    premmy186 Guest
    holden are aways dodgey with there dynoes, thay always understate the kw on em. so add a few onto both, but then add 15 years of driving onto it, so realistically that statements pretty vague.
  17. #17
    Pretender's Avatar
    Oct 2005
    Sunny Rockingham WA
    Series I VN 88 - 91 125kw
    Series II VN 91 & VP 127kw
    VR 130kw
    This is what I've been lead to believe by Holden.
    Never
  18. #18
    05 VZ
    Nov 2005
    i had a vn s2 that had 151kms on it n managed to blow that up, got s2 vr engne fitted i rekon the vr goes so much harder, got those vr iridum ngk plugs the other day biggest rippoff but that with cold air, filter, throttle 100%open mod thingo n zorst, it goes real good especaily at night. all i need is greenfoams tune and im set but vr goes harder
  19. #19
    VP Executive R-spec
    Jan 2005
    The VR engine makes more power than then VP engine, it runs more compression and uses less fuel, be happy
  20. #20
    Jan 2006
    watsonia
    ok so i might of got a better deal but that engine is now blown and im gonna do it up, now is this engine some kind of ecotech and i just want to thank everyone for there input
  21. #21
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
  22. #22
    Jan 2006
    watsonia
    Quote Originally Posted by VN Calais 5.0
    If its a vr engine it is not an ecotec! As Hozy said ecotec did not come out untill the vs.
    ive got this mate who has a vr and he swears by it that its an ecotech?
  23. #23
    Jun 2005
  24. #24
    Jan 2006
    watsonia
    no worrys then i will just have to tell him to wipe his chin thanks VN Calais 5.0
    where you from im from watsonia, northern suburbs
  25. #25
    VN Commodore
    Feb 2006
    the vr "equipe" came out with an ecotec. they put them in the last of them to give the a try out.. i know a bloke who had one.. might even still have it too..
  1. Bloody Car again
    By greg644 in forum General
    Last Post: 29-04-2007, 03:12 PM
  2. Bloody Car
    Last Post: 28-04-2007, 04:09 PM
  3. bloody VS headrests
    By Brycestro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2006, 09:09 AM
  4. bloody kids...lol..
    By rattattack1313 in forum Jokes/Humour
    Last Post: 29-03-2005, 06:25 AM
  5. I got a bloody fine and....
    By vn2nv in forum General
    Last Post: 18-11-2004, 08:20 PM
