Results 1 to 16 of 16
Thread: VP VN gearbox Numbers
    92 Vp SS 5.0Ltr
    Feb 2006
    Lakes Entrance VIC
    Default VP VN gearbox Numbers
    Hey there, just a quick question about the model numbers on the gearboxes for VN's and Vp's.
    My auto VP transmission is a MD8
    My manual VN transmission is an M78
    Now im wondering:
    Are the Manual gearboxes in VP's also M78's?
    And the auto VN's are they MD8's?
    Thanks if guys can help me out.
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    92 Vp SS 5.0Ltr
    Feb 2006
    Lakes Entrance VIC
    VX S2 S-Pac
    Oct 2005
    sorry to bump an old thread but if they ran the same box whats the difference with the number printed on top...like my VN one has 1HD and my VP has 4HD n i know the VR has 5HD for some...but does that change anything?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    i dunno if this is true but i have herd that if u replace the auto in the car (vn/vp) then u have to replace it with an auto with the same number??? i doubt.. but i do remember reading this somewhere
    i too will like to know what is the differance with the differant numbers?
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Can you get a pic of the compliance plates where those numbers are?
    They sound like a trim code or something.
    VN-VS i can say are the same - MD8 is Auto, and M78 is manual.
    This is my VPs break down just to give you some reference points.
    6H8 VP X 19 U P L123456 (build number changed for privacy, hence 123456)
    World Manufactures Code
    6H8: General Motors Holden
    Model:
    VN: VN Model
    VP: VP Model
    VR: VR Model
    VS: VS Model
    Luxury Code:
    K: Executive
    L: Berlina
    X: Calais
    Body Code:
    19: Sedan
    35: Wagon
    80: Ute
    Engine Code:
    H: 3.8L V6
    U: 5.0L V8
    Model Year:
    P=1993
    Tag Number:
    L= Adelaide - Elizabeth Plant
    123456 = build number
    And my option list just for kicks
    19l - exterior paint - anthracite - w/ a9f
    62l - interior trim - classic beige
    a8h - ??
    a8x - international pack
    a9a - vp upgrade 23oct '92
    aq9 - front seat bucket - passenger and driver reclining
    c61 - a/con front auto control
    gu4 - axle ratio - rear 3.08:1
    je5 - anti lock braking system
    nv7 - variable effort power steering
    ph7 - wheel - 6.5jj X 15 alloyed style
    qak - tyre - 205/65r15-sl-r-st-tl-94v
    va1 - radiator standard
    xw6 - paint finish metallic
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VX S2 S-Pac
    Oct 2005
    those numbers arent on the comp plate, the plate does say MD8 on all of them but then again the engine code is the same from VN up to the VS and didnt look any newer than that but how can the VS engine be same as VN as they say they are all LG2 i think
    those numbers are whats printed on the gearbox itself, like a little sticker on top with codes...
    and i will also very soon find out whether the 1HDM is interchangable with the 3HDM as im half way thru changing a motor over but i kept the original g/box which was a 3HDM...so far looks as tho everything is pretty much the same
    STEALTHY™'s Avatar
    Jan 2005
    ohk, sounds like your talking about the ratios in the box. But i don't know what they mean (might have a look at mine and see what it says, its sitting in the boot after all haha)
    Also the VS engine isn't the same as VN, there was 4 codes, buick V6, V8, Ecotec V6 and super 6, i just too out the 2 that weren't applicable to my car.
    cheers sexy
    VX S2 S-Pac
    Oct 2005
    i dont think its ratios cos i know the two ratios are identical for these cars (1HDM and 3HDM) i think it must be like a model of box or something cos it just keeps counting up, last i think i saw was a 9HDM which was in the VY.
    and i know theres definitly a difference in the VS and VN motors but like on the compliance plate where it says TRANS: MD8 just before that it has ENGINE: LG2 (i think) and i was comparing and saw a VRs2 and VS has TRANS: M30 but the engine code was the same on the VS as the VN which made me think that MD8 doesnt mean alot and that it has more to do with the #HDM...oh well
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Here is 2 types. Manual & auto
    I'll look up the other codes tonight when I get home from work.
    and 3 Dangerous non ABS VN's
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    heres an interesting pdf, i found it a while ago. it lists all the gearbox versions for each model commodore. i think the numbers on the box, eg. 4hdd, 6hsd, etc. denote the type of gearbox, 4l60 or 4l60e, floor or column shift, supercharged, and in general, are just labelled after each update. ie, they fix a niggly problem in one version, it gets a new label, so you know it doesnt have that problem
    http://www.acdelco.com.au/Assets/acd..._catalogue.pdf
    VX S2 S-Pac
    Oct 2005
    the photo of the auto VN comp plate has a different engine code :S and its a 91 model and then the 88 model has the LG2 engine code which is the same as the code written on the plate of even a VS
    VX S2 S-Pac
    Oct 2005
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by tyrefryer View Post
    The LB9 is the V8 engine code. LG2 is just a 3.8L V6 code.
    The VT has the largest group of engine codes in the VIN. EG the VN has a H for a V6 or a U for the V8 or K for the Group A.
    A VT can have - H, U, L, M, N, P & F. Thats a 3.8, 5.0, 5.7 (Holden) 5.7 Gen3. The N is a 195i engine........
  15. #15
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by jas98 View Post
    We had a vp box in a vn untill it packed it in so now it has a vn box back in it.
  16. #16
    VS SS (BT1)
    Jun 2008
    I have a Series 1 3.8L Buick with a shift kitted auto in it, and I have a series 2 3.8L Buick with 5spd Manual. Series 1=Sedan, Series 2=Wagon. the Series 1 is a 4.2L stroker and I wanted to put it in wagon with 5spd behind it. This could not be done because series 1 and series 2 both have different input/output shafts on the gearbox/transmission.
  1. Vin Numbers
    By gsmrobinson in forum General
    Last Post: 14-03-2012, 07:00 PM
  2. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  3. Vin Numbers What Do They Mean?
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2006, 01:12 AM
  4. VE Numbers.......
    By blackahcdx in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-08-2006, 01:04 AM
  5. hi what does these numbers mean?
    By richo_69 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-10-2005, 04:33 PM
