Results 1 to 6 of 6
Thread: LSD Diff centre
    VN Commodore
    Feb 2006
    Default LSD Diff centre
    does anyone know what other cars you can get diff centres out of for a vn v6.. i have heard of people using pintara's centres. any info would be good
    Frd_thmsn Guest
    The Vn's are a Borg Warner type 78 , I wonder if there are any other cars using this diff? I will have a look under my old (off the road) fairlane , that had a LSD , maybe its the same type of differential.
    It would be good if you could find a list of compatible diff centres.
    VN Commodore
    Feb 2006
    it would eb great to have a list.. there is a heap fo centres you can use, but i don't know what they are...
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    pintaras have 4.11 gears
    skylines have 3.89 and 3.73 gears
    fords do have a bw78 diff that run 2.7s but who wants that in your commodore
    thats all you can use but....
    you can only use these GEARS in your commodore but you CANNOT use the CENTRES (so kiss by the ford lsd idea) from these diffs as they are only a 2 pinion 25 spline centre where as the commodore have 4 pinion and 28 spline centres
    when changing gears you cannot simply swap and go you must set the lash and pinion deoth using shims and a lot of putting it together and pulling it apart to get it perfect
    you must use a dial guage and get the toerances between 0.008 and 0.012 of an inch.
    if you want to attempt this job then read this guide for a 10 bolt diff we have a 9 bolt but the 10 bolt is very similar
    if you dont have the tools needed then it will cost you just as much for them as to pay a diff joint to do it..
    its a time consuming job but it can be done anyway read this
    http://www.fullsizechevy.com/fscu/axletech/
    im not admiring your car im looking in disgust
    VN Commodore
    Feb 2006
    thats for that mate... i have been wondering about it for a while now.. something to look into in the near future.. is there a BW diff that is a 3.45. i was sure there was a car that had one in it..
    VNV6VENGEANCE's Avatar
    VNV6VENGEANCE is offline VeNgeance
    VN Turbo
    Jan 2006
    adelaide,sa
    All VL's come standard with 3:4:5 gears. VN's have 3:0:8. The higher the ratio the better. Best bet is to go to a wreckers and offer em a hundred bux for a VL Diff. Take the internals out yourself and put them in your diff. My mate had this setup in his VN would easily beat me off tha line and i have the standard 3:0:8 gears. Even better is a VN diff with 3:4:5 gears with minispool. you will kane ppl off tha line
  1. FOR SALE (SA) minispool+diff centre
    By winton in forum Parts And Other Items For Sale
    Last Post: 16-10-2007, 10:04 PM
  2. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
  3. Lsd Diff Centre What Will Fit
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2006, 11:44 AM
  4. vp - vs diff centre
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2006, 05:03 PM
  5. VL diff centre, single spinner
    By TAILS83 in forum Parts And Other Items For Sale
    Last Post: 14-04-2006, 05:36 PM
