Results 1 to 8 of 8
Thread: Engine light while driving
    Dezza's Avatar
    Dezza is offline your local HSV dealer
    Cammed up Vy Clubby
    Feb 2004
    Default Engine light while driving
    OK i just went down to get some kfc and while driving i noticed that my engine light on my dash popped up, it went away after about 20 secs then a minute later it come on again stayed on for around 20 secs then went off , Then it happend a third time, it came on a gain so i counted how many seconds it came on for and it was around 20 secs, i have no idea wat is the cause of this the car was driving fine it idled fine it was resposive and it appeard to have no problem, i also suspect that i have a oil pickup problem as my car wont start in the mornings till my oil light goes off i usally have to crank around 20 secs then the oil light goes off and the fuel pump comes on, i just put in new fuel pump filter and lines cuase of this problem then relised it is probbay the oil pickup i havent checked yet with an oil gagge tester thingo as i dont have one any help on the subject of the engine light comming on would be great as i dont wont my engine to blow up
    warney's Avatar
    warney is offline did you say bukakki party
    VL skid car what else are they built to do
    Mar 2005
    use the search button.....its your friend and look up engine light or diagnosis
    VL
    Jul 2005
    SA, Mount Gambier
    Means your ecu has an error. Do an ecu diagnosis and and you will find out the problem.
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    ok i have done numerouse ecu diagnostics and it comes up with nothing i did search and i found nothing that can help me
    VL
    Jul 2005
    SA, Mount Gambier
    Dezza's Avatar
    Cammed up Vy Clubby
    Feb 2004
    SV3800
    Jan 2006
    VL
    Jul 2005
    SA, Mount Gambier
    Yer try resetting your ecu, take her for a drive and see if you engine light comes on.
  1. Driving Light Options
    By nickbalcombe99 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-04-2006, 06:29 PM
  2. VX S Driving light installation?
    By grimavxs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2006, 10:29 PM
  3. Hills driving then engine check light on ?
    By f_vos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-12-2005, 09:15 AM
  4. Vp Driving light Question
    By Madhouse_Dave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2005, 12:12 AM
  5. Driving light
    By cdsam in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-08-2005, 09:04 PM
