Results 1 to 9 of 9
Thread: think my thermostat is stuffed
    beefcream's Avatar
    beefcream is offline Lethal LOKKA
    VS SS 5speed (project) VN exec v6 (daily)
    Sep 2005
    South,Adelaide
    Exclamation think my thermostat is stuffed
    hey,
    im tryin to find where the thermostat is? my car now gets hot real quick the top radiator hose is hot but the lower right one is normal. does this sound like the thermostat or somethin else?
    the radiator also isnt very hot after a drive, is it ok to drive it to a merchanic or will i do big damage?
    thanks,
    Chris
    VS SS - Street/Show Project [BEEFY]
    http://forums.justcommodores.com.au/...-beefy-v2.html
    HID Kits from $100 - Installation available PM FOR DETAILS
    My00 Wrx 240kwatw
    Apr 2005
    It sounds like your radiator is blocked. You can either buy a new radiator, or take it out and give it a good flush with the hose. Piss easy to do at home, no need for a mechanic.
    I highly doubt its your thermostat, most of the time they are stuck open not closed.
    However If it is the thermostat, and you have a series 1, your going to be in trouble.
    Its located right at the back of the engine, underneath the throttle body. 7/10 guys who try to change it fail, because the housing welds itself onto the engine block over time, making it near impossible to get it off and change it over without breaking it.
    I was lucky, mine came right off. But my uncle is a mechanic, and he has had lots of trouble with these series 1 vns and thermostats. Not to mention all the other guys on the forums with this same problem.
    VN Commodore
    Feb 2006
    i broke mine. but they are cheap from the wreckers. if it is your radiator don't pay to much for one.. they are not worth anymore than 130
    SV3800
    Jan 2006
    Sounds like the thermostat my ser 1 VN did the same wasn't a problem except where its located its a bitch to manouve around the plenum.
    I replaced the ther housing even thought mine was ok for $35ish why not just change it HTH
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    ive played with my thermo stat several times now, once u do it once its easy, take ur tb of first, then undo ur rubbers pipe going to the thermo stat housing then undo the only bolt, it will tkae a alot of wiggling but u should get it off, only a little bit of coolant will come out, then pull ur old one out and put ur new one in the same way, my car never had one so i put one in, i paid 10$ for mine from holden
    check my ride
    http://forums.justcommodores.com.au/...ad.php?t=16665
    and feel free to comment
    Boofe Guest
    I've had my thermostat stuck closed in my previous car "Diahatsu Charade".
    But yours sounds like the radiator is blocked...
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Yeah does sound like the thermostat. My dads patrol thermo stuck closed and overheated bigtime. replaced it but never ran the same and chewed the oil so therefore had to take heads of and get it remachined and evrything was warped. The themo in my vn i think is stuck open as it never gets off the first 3 bars on the guage but i dont worry about changing it as it is a bugger of a job mentioned previously
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    if ur thermo is stuck open, u really should change it, i never had one and mine bearly even ever got of 0, it just sat on the needle all the way to work in the morn, really bad for the engine, so u should fix it... but yeah it really aint that hard
    check my ride
    beefcream's Avatar
    Sep 2005
    South,Adelaide
    i took the car out this morning for about a hr and gave it a hard time on the way back from the bay. the needle stayed on C for about 20mins and then after that made its way to the first marking (level 1 cluster) and stayed ther. Seems to be ok now.. I HOPE
  1. Thermostat
    By joshovn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-09-2007, 07:01 PM
  2. thermostat
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2007, 06:58 AM
  3. thermostat
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2006, 01:14 AM
  4. Thermostat
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 09:53 PM
  5. thermostat
    By sully in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-08-2005, 12:33 AM
