yesterday i took out the radiator to check it all out and someone thought it would be funny to turn the car on while it was out causing a shit load of ****ing oil to go everywhere, anyway right i put everything back together and the car will start but not go into gear, so my question is: was it transmission fluid that leaked? the way my car is now is like riding the clutch with it barely movin when i even rev to 5 thousand rpms, would i just need to top up all fluids that were lost? by the way i got an auto the riding the clutch thing was just an example of wat it feels like, and also where abouts to i top up trans fluid to? thanks heaps
common i need some form of help i'm sick of hangin on the internet waiting for someone to reply when i could be out n about
its the weekend have sum compassion
yes it will be the fluid. Auto as far as i know run on pressure, so with out oil they sorta just sit and the gears dont engauge. So top the oil up and check it while its runing to get the correct level. I used to leave the handbreak on and leave it in first to check the level. Hope this helps
.:Blown VT V6, DAJ37:.
thanks heaps buddy
thats what we is here for let me know how it goes
also do u know were to fill up from??? if not its were u measure how much oil is in ur tranny its like a pipe coming up to ur engine with a a dip stick in it, keep ur carm warm while adding oil, they measure by the engine being warm not being in gear, cause wen ur oil is hot its thinner so thats why autos are rough wen cold or have to much oil
