got this clunking noise from back of car not all the time but seems to only happen on big bumps or heavy cornering has any one had this prob
have a look at your trailing arm bushes or uni joints...Originally Posted by stockvp
bushes look fine but noticed rubbing on my exhaust from tailshaft
rear sway bar rubbers and upper control arm right side bit hammered would these be making that noise
is your exhaust moving or your tail shaft?Originally Posted by stockvp
grab your trailing arms and see how much movement there is,if theres lots,thats your knock.....but this rubbing on the exhaust...
yeah my exhaust moves over to it and i cant tell if the tail shaft is moving how do i do that
just had it looked at and guy is gonna fix 2moro morning it was the bloody exhaust hitting tailshaft grinded a bit off lucky theres no hole
yeah i ahd same problem, the exahust was coming off the rubber, and bouncin of the tailshaft, i got some mig wire jimidy up the zorst onto rubber an went sic with wire, it hasnt moved since
