any one got any good advice on removing the disc brake lines from the diff and rear axle housing? taking it all out but i can't disconnect the lines at any of the points, the joints wont budge a bit, i've tried everything. help?
ah i seeeeeee, alright gotta chase down some vice grips, any other suggestions, n is this for unbolting them, or is there an easier connection i can take off
there 10 mm bolts, and there just ###n stripping, im thinking i might go buy a pair of vice grips and a 9 mm, bang the ###n 9mm on and hopefully it'll work
nuthing, couldnt get it, tried everything. cut the brake line lol, need a replacement now. got a donour parts car so its ok, just hope its not the same on the other.
