hey guys I have a 91 vn wagon that up till a few weeks ago was running perfectly
when driving the car it will occasionally stall.. pull over and it starts again then off we go only to stall again a lil while later but some days its fine all day any suggestions???
umm well, the other day my sisters vn v6 was stalling. we took it to the mechanic and he said the valley gasket needed replacing, and also something else that i have forgotten sorry :P
cat? isnt that an animal? no i dont want one in my exhaust system thankyou very much...
my ride \/
http://forums.justcommodores.com.au/...ighlight=seabs
when u stall can u start the car straight away and drive off or does it take a while b4 u get it going again? i had a similar problem just this week, i was stalling and then starting after a while. mechanic changed my Crank Angle Sensor which at the momnent has been working! (touch wood)
are u getting ne engine warning lights?? search the forum on how to do a diagnostic test on ur ecu and see if u get any error codes.
hope this helps!
jezza
no engine warning lights and yes it starts almost straight away
mums is doing it, i have found the problem's, fuel sock is so dirty it's not funny, and the intake manifold gasket needs replacing. has a vacume leak and it stalls, but will re-start straight away
cheers
garth
i am the god of britany spears womanizer on just dance on the wii
Garth,
After stalling. Then re-starting, did you notice if your car had an irradic idle or not? (up and down rev)
nah as soon as i restart if off it goes only to stall a lil while later its off to autocare on monday for i diagnostic so i should know more then
thanx for the suggestions
what does a crank angle sensor cost to be replaced anyway?
i just got my CAS replaced and it cost me $61 for the part and $60 for the labour!
You can buy them for $45 and replace yourself.
Sorry Fitzy , I hate to disappoint you ! but ............... I just changed mine in less than half and hour and im only a Boilermaker!.
