Results 1 to 6 of 6
Thread: Not Starting Badness
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Default Not Starting Badness
    I'm having a crapper of a time trying to get my car to run
    Last night got the car running with supercharger, super 6 injectors, the works
    was runnig way rich (fair bit of black smoke)...
    decided to take it around the block calmly to see if it ran...
    got down the street, car felt fine
    first corner it started sputtering and not wanting to idle at all. managed to get aroudn the block and hasn't wanted to start since... Maybe a little splutter every now and then but no go.
    I've been racking my brain for hours now and can't seem to find anything! Tried a differnt DFI module, tested all the connections and cables etc (all fine) and din't help..
    - I'm getting spark when cranking
    - crank angle sensor is working
    - fuel injectors are pulsing (have now fitted the standard units again)
    - fuel rail is full of petrol...
    - no error codes (ALDL'd it.. nothing)
    - tried two differnt computers, 3 differnt memcals.. nothing
    anyone got any suggestions?
    I noticed one thing, last week when you'd have an ECU with no memcal plugged in, the thermo fan would turn on at ignition
    now with no memcal FAN =not going?
    Any suggestions?!
    EDIT:
    Just had a bit of a play with the fuel rail....
    on the way out of the fuel rail (after the reg) I put a coke bottle and a length of hose ...
    the fuel is coming out, but it's not coming out very quickly. (i.e. i primed it, started cranking for aobut 15 seconds, and only got about 150 ml of petrol...)
    Does this sound like it's nowhere near enough pressure?
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    To all those that viewed -it was the fuel pump A swift kickbox to the fuel tank revealed a fuel pump gurgle - after fuel pump replaced she's running !
    Wonderboy Guest
    yeah standard fuel pump ay. how does she go with the charger? what type did you get? what are these super6 injectors? any good? ive been told to get magna injectors, then bosch ones, then go see petraject.... i just want bigger beasties!
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    super6 injectors are the factory units for the factory supercharged ecotec. they must be good, coz the genIII brigade bin the OE's and use super6's
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the v6sc injectors are 36 lb
    magna (holden 5.7) are 24 lb
    ls1 are 24 lb
    std are 18
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    Yeah i just got a standard 2nd hand fuel pump replacement for now (completely blown the budged, but need car running)
    The plan is to get an aftermarket pump that flows a crapton more than the standard one. I had one recommended by an EFI guy - this is only going by memory but i think the standard one flows 160 l/hour, this one flows 240 or so ?
    The 'super 6' injectors are the ones of the supercharged six - $66/each from petroject in mitcham/vermont. for once i was glad I only had to buy six lol.
    Car goes GREAT so far with the charger, very impressed - although I believe i'm only reaching a fraction of it's potential... At the moment the car is running factory fuel system with standard injectors - as it runs VERY rich with the super6 injectors in there. (at the moment it's running lean I assume, but it doesn't see over 3000rpm and 1/4 throttle just yet)..
    As soon as i get my EPROM emulator working again I will (and please correct/advise me Dr. Bob) change the injector flow rate to .08 or so and run super 6 injectors, then start playing with tables to see how well i can get it to run.
    also - does anyone know how the VS/VT ECU handles boost? I've heard kalmaker is the go for engine management, but how do the later models handle it? (is it because there's no MAP sensor?, only a MAF?)
  1. Vs not starting
    By inoutinout in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2007, 11:18 AM
  2. Starting car
    By mark1 in forum Electrical Wiring / Questions
    Last Post: 15-02-2007, 09:33 AM
  3. VN Not starting - HELP
    By ghosty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 01:27 PM
  4. starting....
    By UnderPressure in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2006, 04:39 PM
  5. starting
    By ab56452001 in forum Electrical Wiring / Questions
    Last Post: 04-01-2006, 10:04 PM
