Results 1 to 13 of 13
Thread: fan speed resistor
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Default fan speed resistor
    Hi, my fan for the AC stopped working lately on ALL speeds. my question is would it be the fan speed resistor as i dont want to go and dish out 50 odd bucks for a new one and not fix the problem. Also would the resistor cause all speeds to stop working, i always thought you lost a couple but not all. Cheers
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    From what I've heard if the resistor goes 1-3 dies but 4 normally still works. Check all the connections to the fan motor, and actually check the fan motor itself. You may have just killed the little electric motor that spins the fan.
    Gravity is proof that nature keeps getting us down.
    pauleee Guest
    you're right mouce, if the fan resistor goes, speed 4 should still work as it connects straight to a positive source (ie not through any resistance to slow the fan down). It sounds to me like you have lost all power to the fan speed switch (check your fuses). either that or the fan has stopped working. you need to check with a multimeter if you have power coming into the fan speed selection switch and then if it is going to the motor. If that all checks out, then its the motor. I should think the motors are pretty tough though.
    mouce's Avatar
    Jul 2005
    That motor, is going to be like all electric motors, they will just keep working for as long as the bushes inside them are fine. Once the bushes wear down, time for a new motor.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    I checked the fuse today and it was fine. I progressed further and found that there wasnt even power at the fuse using a test light, so what does that mean? Where could the problem be if its before the fuse? any comments would be helpful. Cheers
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    mouce's Avatar
    Jul 2005
    The blower motor sits behind the glovebox. It's not hard to see, but I don't know how hard it will be to swap it over.
    No power at the fuse? This might be a bit of a blonde question, but did you test the right end of the fuse holder? If there is no power getting to the fan, it's time to start digging a bit further back along the loom to find where the wire has let go.
    I can't remember if there is a relay that is meant to kick in or not, have a look around.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Yeah i tested both sides when i done it to make sure. Odd problem but, so you reckon a wire has come loose. I will have a look but electrical isnt my best subject. Maybe even a relay or something but might have to get it to sparkies. Also another question, I know that the engine fan is supposed to turn on when the A/C is on (as it can't know that the AC fan stopped working), and the other day when it was sitting there it got to about 3/4 on the temp guage and it didnt kick in so could this be a symptom of the problem aswell.
    Is there any way of testing a relay to see if its dead???
    VR Manual Sedan
    Sep 2009
    Quote Originally Posted by pauleee View Post
    speed 4 wont work, only 5 will. You have 1,2,3,4 and then high, only the high will work!
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by jaylee View Post
    Woah huge thread DIG!! On a commodore (vn-vs anyway) there is only 4 fan speeds, no 'high', but in any case the fastest fan speed will always be non-resisted.
    Power is measured in DECIBEL
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    my vn has 1,2,3,High and only works on 3 and high lol but it still works so i don't care hahaha
    VN Calais With All The Factory Fruit I Need!
    98 vt s pac
    Feb 2009
    Corowa NSW
    hope ya find out mate ive got the same prob with my vs except some days it works after a while other days it wont work at all
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by mynameisearl View Post
    I fixed this many YEARS ago now mate lol, was a bad earth nothing to do with fan speed resistor at all
  1. Vt Fan Speed Resistor
    By gsmrobinson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2010, 01:42 PM
  2. How to get to the Fan Speed Resistor?
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-12-2008, 02:28 PM
  3. Fan Speed Resistor? VN
    Last Post: 16-05-2006, 08:25 PM
  4. Vn-vs Fan Speed Resistor Removal
    By gsmrobinson in forum Electrical Wiring / Questions
    Last Post: 12-08-2005, 03:15 PM
  5. Fan speed resistor
    By Bec in forum Electrical Wiring / Questions
    Last Post: 06-08-2004, 12:59 AM
