help me, i cant get any other door, except for my drivers door open.
key wont turn all the way, and lifting them up doesnt make the lock click over either!!!
any ideas would be great
Take the red tabs off your locks and spray a heap of wd 40 on the locking mechanism.Leave it for a while then try.I had this problem for a long time with my vp and after doing this a few times my central locking started to work again.
Take your trim panel off, remove internal and exterior door handles and check the actual door lock mechanism that actuates the striker, a bit of a pain in the arse but thats what happened to mine. The plate that every thing bolts to was bent in mine
^^^That would work fine, but you need to get the door open before you can take the panel off don't you?
How did that plate bend? I thought it was a fairly thick steel plate.
Gravity is proof that nature keeps getting us down.
you may of deadlocked it and thru wear your drivers side wont bring the rest of the doors out of deadlockOriginally Posted by brey9186
Originally Posted by yosy
and how do i undeadlock it then?
Open drvers door remove trim and manualy bring it out of deadlock and check central locking connections
