Results 1 to 5 of 5
Thread: confused fitting disc pads to our vp
    VH Commodore sl
    Apr 2005
    Default confused fitting disc pads to our vp
    hi guys haven't been on for a while cause we lost our password and life has been busy....when we last visited we owned and still own a tidy vh commie which was running crapola due to stock varajet carb which in the end i replaced with the weber off a falcon and now she runs sweet as........finally. having got her running nice we have now purchased an ex hobart police vp wagon... v6, abs, fe2, four wheel disc and her original wedding car white paintwork and body is perfect..we have just sat her on a nice set of 17 inch wheels...i will attach a photo to this if i can work out how? Now my question is.... i went to replace pads on her brakes the other day..a job i have done many times on other holdens.........however i made the decision to buy a gregorys service and repair manual for the car while i got the disc pads ..when i read the manual to do the front brake pads after i had removed some brake fluid and got the wheel off it said to remove it says to and i quote "remove the lower caliper lock bolt and discard it" then has a footnote which reads "the caliper lock bolts have special locking compound on the threads and therefore must be renewed if removed" does this mean if i remove the caliper bolts i will have to replace them ??? the section on the rear brakes has the same footnote but doesnt mention discarding the bolts . i am confused and unwilling to undo these bolts until i know whether they need replacing or need loctite...any help would be appreciated...jack
    Attached Thumbnails Attached Thumbnails confused fitting disc pads to our vp-our-new-diva-wagon-003.jpg
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    well i have done mine many times and others that come in at work and yeah you remover the bottom bolt and it should pull up , we normally put grease on the sliding bolts but i guess you could get some special bolts, but i wouldnt worry to mcuh about it, but other people on here ill help, that just my opinion, good luck
    VS S1 Executive V6
    Aug 2005
    Maroochydore
    i'll speak from my pad changing experiences on my VS...
    I have never used loctite on caliper bolts. Never had problems with caliper bolts coming loose.
    Something I've Been Getting Into Lately....
    Get Paid To Surf The Internet!
    Program About To Be Released So I Jumped Aboard...
    http://www.agloco.com/r/BBDB3431
    VH Commodore sl
    Apr 2005
    thanx guys...just as i thought...if i never read the manual i would have just done the job..job will be done now.jack
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by diva and falcoz
    i hate to be the bearer of bad news,now i know people have done thousands of these and to their knowledge nothing has happened...including me
    but if gregory's say the bolt will need replacing..IT does,they have an excellent team of technicians and they know their stuff,i dare say this bolt replacement is a safety issue to cover gregory's backsides....in my 30 years in the trade i have seen my fair share of loose calipers....loose as in just nipped up,not finger tight,just nipped up with a spanner or socket,
  1. VN - VS: Replacing the Brake Pads (Disc Variety)
    By Darren in forum Holden Commodore How-To's
    Last Post: 29-01-2011, 02:05 PM
  2. brake pads and disc rotors
    By damo15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2009, 07:31 PM
  3. fitting new vt brake pads?
    By lil_oneblue in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-01-2007, 05:38 PM
  4. Which Disc Pads to buy??
    By Jock in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2006, 09:24 AM
  5. WTB handbreak cable for VL disc to disc
    By broadtail in forum Swap / Wanted to Buy / Trade
    Last Post: 13-07-2006, 10:29 PM
