Results 1 to 5 of 5
Thread: engine swap
    VS Acclaim
    Jan 2006
    Default engine swap
    Just swapped engine an gearbox (auto unfortunately) in my VN with one from a VP station wagon. (Mine had lots of real hard k's on it (go the grassy paddocks)).
    While it was mostly straight forward, a strange thing has happened;
    at 100km/h it used to pull somewhere around 1800-1900 rpm.
    Now it is sitting a needle width above 1500rpm.
    Was there any ratio changes between any of these models? or is it likely to be some sort of sensor not right (it feels like its doing 1500 an i keep up with cars on the highway).
    It is confusing me somewhat so any help is greatly appreciated.
    (am wrecking a vp wagon as well if anyone is interested(and vn engine))
    VP WAGON V6
    Mar 2006
    where abouts you at??? i need a few vp parts and im interested in the vn engine
    MikeVXSS's Avatar
    MikeVXSS is offline !!!GO TIMMY GO!!!
    VX SS 5.7
    Oct 2005
    Bunbury, W.A
    ill swap you one for a lolliepop. lemon
    Ash to Ash
    Dust to Dust
    Fade to Black
    ....The Memory Remains....
    ..RIP TIMMY..
    VS Acclaim
    Jan 2006
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    I have a VN that sits on about 1500rpm in overdrive when im doing 100km/h. Perhaps it was just your old engine, although I do have a 91 model with the VP update engine so then again it could simply be the slight changes between engines and the extra 2kw and 2NM of torque.
  1. engine swap?
    By jazzawithvg38 in forum Straight 6 Development And Modification
    Last Post: 15-11-2007, 07:10 PM
  2. LS2 engine swap
    By leonthalion in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2007, 05:11 PM
  3. engine swap
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2007, 10:26 PM
  4. engine swap (vk to ??)
    By phat_com in forum Just Commodores Polls
    Last Post: 26-06-2006, 09:28 AM
  5. Engine Swap
    By Dezza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2006, 07:16 AM
