Results 1 to 5 of 5
Thread: Leaking Water?
    93 VP
    Dec 2005
    Default Leaking Water?
    I have a leak in my car that i cannot track down. It has rained recently but the car was under cover for 4 days and it is still leaking when driving. Basically it is leaking from behind the dash down the drivers side of the gearbox? The water hiots my leag about half way up my calf and only when in a turn. The water appears to be fairly cold so i was thining it might be A/C related or something? Any idea?
    VX Berlina 2000 S1
    Apr 2004
    Melbourne - Victoria
    I have the EXACT same problem...
    I think it's to do with airconditioning overflow, that should come out under the car... last time mine was clogged.. and a quick piece of wire or sometihng up the tube fixed it... but now 4 months later, its doin it again... does anyone know is there 2 pipes or is the another cause for this problem.
    MR T.: I pitty tha fool who doesn't drive a commodore
    Ride: 2000 Series I V6 VX Berlina.
    VP Executive
    Feb 2006
    Cleveland, QLD
    I had this same problem with my VP the day after I bought it, so I took it back and they put it up on a hoist and the mechanic grabbed a long screwdriver and gave some rubber grommet a push and heaps of air conditioning water came out. This is a very common problem with the VP's apparently. This problem is caused by the rubber grommet (or whatever its called) under the car blocks the air hoses and therefore leaks out whereever possible, usually on your leg when going around a corner.
    I can't really help you on the exact location of this rubber grommet, but its somewhere up the front dear the diff. (I couldn't see exact location as I wasn't allowed in the workshop when the mechanic did it).
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    DO NOT USE METAL!!! You risk poking a major hole in your heater core, which means that your dash will need to come out, and a whole lot of other stuff as well.
    Plastic cable ties work just as well and don't do any damage unless you really punch them in really hard.
    Gravity is proof that nature keeps getting us down.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I have leaves that drop into the bonnet and come under the feet after a couple of days. If they can get in god knows what else could, Water.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  1. VR leaking water next to left foot
    By RedAdare in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2007, 01:41 AM
  2. Water Leaking Into VX Boot Garnish...plz help!
    By B-T-GiZzLe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2007, 11:04 PM
  3. Boot leaking water.
    By KLatham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-01-2007, 09:26 AM
  4. A/C leaking water in cabin
    By Mr Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2006, 06:24 PM
  5. VP Leaking Water Leakage In Boot
    By Sambo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2004, 01:01 AM
