Results 1 to 9 of 9
Thread: vn wont start
    vn
    Oct 2005
    Default vn wont start
    i just drove home from work last night and parked the car for 10 minutes
    got back in to take the kids to school and nothing
    i have power but no signs of trying to kick over
    checked the fuses and all are fine but there is a 60amp fuse under the bonnet labelled mains which i cant remove.either side of it are 2 30amp fuses which i easily removed but the 60 wont budge
    i dont know what else to try
    any ideas
    thx
    May 2004
    VX SS M6 // Project Rx7 Turbo // 323
    Dec 2005
    Move the stick down to neutral and back to park.
    If that doesnt work try to start it in neutral.
    The car wont do anything if it is in gear. Sometimes the electronic part of the gear selector plays up and that helps fix it.
    Hope it helps.
    Rian
    vn
    Oct 2005
    the cars an auto and i have tried starting in all gears and moving selector around
    vinnywelsh's Avatar
    vinnywelsh is offline Bored Technician
    VN V6 3.8L Berlina
    Aug 2004
    Im going to guess that it could be the crank angle sensor! check out this thread
    Car just stops and after 10 min starts again
    - 1st JC Cruise, Voted Most Stock Car -
    vn
    Oct 2005
    i have half sorted the problem
    turns out it may be the ignition switch or the inhibitor switch
    i have now found out how to eliminate the starter motor as the problem if anyone is interested to know
    under the bonnet there is a relay that reads start.pull it out.
    if you grab a piece of wire and bridge out number 30 to number 87 while the ignition is on(the numbers are on the base of the relay) you will get some sparks if it is the starter motor,the car will start if it is another problem e.g inhibitor or ignition.
    hope that helps some others
    cheers
    VN Calais 89'
    Mar 2006
    brentasaurous Guest
    sounds a little different, but this is worth a try
    after mine cut out it wouldnt start again. i had all power but when i tried to turn the key to its final position all lights disappeared and the engine didnt even attempt to crank over.
    cuts out?
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by invasion
    any ideas
    thx
    i have had it happen in a manual,all it was,was the simplest of things....battery
  1. VX wont start
    By _VX_S_ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2007, 02:50 PM
  2. VS V8 wont start
    By rus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2006, 11:39 PM
  3. It just wont start...
    By VL86Berlina in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-02-2006, 07:08 PM
  4. why wont it start???
    By only-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2006, 03:15 PM
  5. Help wont start
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2005, 05:16 AM
