hey there, im just wondering how hard it is to put a series II coil pack on a VN? do i need to chaneg the DFI module as well? any help would be great,
thanks guys
cheers, nick
yes, dfi and coils, unbolt and bolt on, easy mod, its a tight fit with some of the leads, maybe a new set of VN II leads while your at it
What are the gains from doing this? I've asked before, but i forget.. Is it worth doing?
Teere are no real gains in changing the DFI. The only good thing is that Series II coils can relace indiviual coils instead of the entire DFI
right. So if you had a Dodgy s1 one, it would be a good idea to swap it to s2, so you only replace coils you need... thanks
i've heard that the s2 coils put out a bigger spark is this true???
dont know abour bigger spark, but the spark would be much cleaner, stronger in terms of unit overheating during driving, etc.
