Results 1 to 12 of 12
Thread: buggered engine, oil every were
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    Default buggered engine, oil every were
    hey guys, i got a mate who has a vn series 2 commy and it seems that his mechanic says that the seal at the end of the engine around the crank were the fly wheel bolts on(but still in engine) has gone, and apparently its a 2 peice seal and would take awhile to fix, does this sound right?
    now another thing is, he wnats to buy my eninge in the shed buts its a manual s1 motor, and he has a auto s2 motor and a stage 3 shift auto, would my engine and his trany go together?
    check my ride
    http://forums.justcommodores.com.au/...ad.php?t=16665
    and feel free to comment
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    yeh they should still go together... there was only small changes made to the top half of the engine not the box pattern on the back as it is still a turbo pattern
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by VN-88
    no it won't....series1 is 6 bolt,series2 is 8 bolt,both auto and manual
    sorry... tranny will fit but he will have to get 6 bolt flex plate if he's using your manual motor
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    thanks samuels, i thought that, but why is there always some one who gives in incorrect answer, i mean i was almost 100% sure but had to check, how much is a flex plate?
    check my ride
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    it would take a bit of messin round, im no mechanic, but after stripping down my new motor, and asking dad lots of questions, youd have to unbolt the auto, remove sump, unbolt crank? not sure on that one, and change seal, if its done incar, lots of hours, out of car, piss easy. i think
    Sep 2005
    good second hand one 50-$90
    new anything up to $250+
    Sep 2005
    Quote Originally Posted by hakhawk
    easier to just take it out of motor then you dont end up with a sore back
    split box from motor take sump off,unbolt your rods,drop crank,replace seal,installation is the reversal with attention to ...ensure seal is fully home ,new sump gasket...and of course OIL..
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Bloody expensive to replace the rear main seal if you pay for a workshop to do it. I've been quoted up to $900 for them to do mine. At the moment though it's not dead yet, just leaks a bit.
    Thicker oil slowed my one down, but it's going to need to be done sometime.
    There really isn't an easy way to do it.
    Gravity is proof that nature keeps getting us down.
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    yeah he has a mechanic doing it... id pull the eninge out and strip it for him, but really i dont no if i can be ****ed. engine are an easy thing to tinker with and strip, but if i **** it.. well i odnt wana thats all, and after doing my tranny i dont think i wana pull the engine out
    check my ride
    ScottB_33's Avatar
    ScottB_33 is offline Go Hard or Go Home
    VTII Berlina Supercharged
    Oct 2005
    Nowra
    The series two engine is a much better engine than the series one with changes to both plenum chamber and idle quality. The series two engine is basically the same as VP but in a VN body which is why they are great buying if you can find a good one. The rear main seal on the VN is not that hard to fix if you have the right tools. A specialist tool called a "Sneeky Pete" is available from Repco and tools stores and it enables you to pull the rear main oil seal out while the engine is still in the car. Yes you still have to drop the exhaust/starter/tranny inspection cover/crossmember and then the sump but hey these normally all leak anyway at this age so fix whatever needs to be done while its all out!! Then its just a matter to loosen the crank allowing it to drop down a little then remove the old seal and feed the new one into the slot. The hardest part is getting the seal to sit correctly and secured around the crank. Mechanics charge so much because of warranty with this system as there still is the possibility of leaks and how would you like to do all this work again for free under warranty???? If all goes well then yes the motor will not leak and you will be a happy camper. If I was doing the job I would much rather do the rear main seal than pull the engine out which may also leak down the track even more!! If you came to my shop that is what I would recommend.
    mouce's Avatar
    Jul 2005
    Yeah, but if you're going to all the hassle of pulling the engine out of the car to do it, it's a good excuse to do a little bit more work on the engine while it's out
    And let's face it, dropping the tranny and the sump and all that, you might as well yank the engine anyway, that just makes it that much nicer working on it, unless you've got a car hoist at home.
    Sep 2005
    Quote Originally Posted by ScottB_33
    well i certainly wouldn't reccomend that to my customers,it's a cheat way out with no guarantees...i would rather take motor out and do it properely...a day and it's done,your way is far more time consuming...my opinion any rate
  1. New VZ Buggered
    By 88GreenVN in forum The Pub
    Last Post: 22-12-2007, 11:40 PM
  2. i buggered the a/c up
    By mattbethvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-04-2007, 06:16 PM
  3. Buggered Gearbox!
    By sganro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 09:25 PM
  4. Trans buggered?
    By drewins in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2007, 04:26 PM
  5. Vn Airconditioner - Buggered From Non Use
    By seedyrom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2004, 06:04 PM
