mikes 92 veepee against andy's 03 vy uteblah blah balh long story short, vp ran a quicker time than the vy.
ok now for my query, my sump is leaking and i want to know if anyone has jacked up the engine off the mounts before to tighten up those bolts at the back?? if so any help would be much appreciated.
jokes..ahahaha i get jokes
Can jack up the engine using a length of wood under the sump to spread the load = same as engine sitting on ground.
Simply tightening the sump bolts won't fix the leak though...
yeah had the same problem on mine, could only get to the front bolts, tightened them up (they were able to be turned by hand) and hasn't been leaking since, but still have got to get to those rear ones
Rolling in a 5.0
