Results 1 to 13 of 13
Thread: running engine out of car
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    Default running engine out of car
    hey guys, as it say above what would i have to do to fine up an engine and have it run just for a min or 2 whilst out of the car, like on an engine crane. what would have to be conected and were ect
    also would the tranny have to be on it, or can i fire it up with out the auto on it
    check my ride
    http://forums.justcommodores.com.au/...ad.php?t=16665
    and feel free to comment
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by VN-88
    no tranny doesn't have to be on engine,all you need is a container full of fuel,not a big container just put enough fuel in it for it to idle over for a minute or 2,have your starter hooked up to flex plate,bypass the starter,"geez" it's been ages *LOL* since iv'e done this...work out what wire is what and touch them together,not sure how it's going to run unless you hook up the ECU with it.
    bbad13 is offline bbad13
    VZ Exec. Wagon
    Mar 2006
    Yorketown s.a.
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    i got the ecu on it, but what wires will need to be on it? or on the battery
    check my ride
    Sep 2005
    just the front wiring loom,from ECU front wards ,(to all sensors)don't really need the battery...doesn't matter though...
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    well i want it running smooth, cause im gonna replce all oil and filters and all that crap and i need to be able to hear if its still clunking
    check my ride
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Without an exhaust on it, you're not going to be able to hear much at all, not in terms of clunking anyway. I could see it being fairly loud.
    Gravity is proof that nature keeps getting us down.
    Aug 2004
    it will be loud with out mufflers not death loud but enough to piss your neightbours/mother off.
    if i were to start it up out of the car, i thought about it but never did it.
    i would but the motor on the floor on a ruber mat or something.
    leave the transmisson on.
    leave the y-pipe on and you could probley connect a muffler to it.
    have the engine crane holding so it can jump or ran away, just have the crane to stop it falling over if it trys to.
    connect the ecu up to it/wiring looms and a battery. you will probaley need like a full loom engine bay and relays and igntion etc.
    then turn the key. maybe have some mates come around incase something goes wrong. always a good idea.
    thats just how i would go about it have fun
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    i sorta cut the pipes with an arc, but ill just weld the old pipe back on i mean i t doesnt matter if it leaks... will i need all the relays like the starter motor one and that cause i sorta just went nuts wen pulling it out. also will i need a radiator on it or water ?
    check my ride
    Aug 2004
    as for the radiator dont worry about it pull the thermostat out and just run a pipe where the radiator should be so at least its pumping water through its self.
    missus (in more ways than one)
    Sep 2005
    yeah leave the tranny on, so you can hook up the starter motor into the bellhousing/inspection plate, depending on model.,
    VP WAGON V6
    Mar 2006
    HSV VX Clubsport.
    Sep 2004
    Wyndham, Western Australia
    Eres how ya test a Supercharged VN Group A 5L :P
    Attached Thumbnails Attached Thumbnails running engine out of car-engine4.jpg
    MSN: dangerman3000@hotmail.com
    Plates: (WA) [ S73AL7H ]
    Never Look Back
  1. Engine running rough
    By Spindry in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-11-2006, 06:43 PM
  2. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  3. fan keeps running when engine off VP series II
    By oomwoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2006, 02:53 AM
  4. VR Engine running rough
    By DaddyCool in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2006, 01:19 AM
  5. VP Engine running badly
    By Tadeusz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2005, 10:22 PM
