Results 1 to 2 of 2
Thread: Strut bearing, how to replace it?
    VP Executive R-spec
    Jan 2005
    Default Strut bearing, how to replace it?
    Just wondering if I'll do this myself or not, Can you drop the strut off the tower and drop it down far enough to undo the bolt and replace the bearing without pulling the whole strut off?. I was just want to know how much effort it is to replace just the bearings, the bad thing is that I have some new shockers that I should put in while I have them off but I'm not sure if I really want to do that
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    you can get away with disconnecting a few things and pivotting the strut out the side of the guard when it's still connected to the wishbone etc...
    but for the effort of doing that, you might as well do the few extra bolts.
    it's not a hard job at all, but you will need a rattle gun for the bearing plate nut.
    and you might as well put the shockers in, because once you take off the bearing plate, it's one more nut to replace the shock absorber
  1. strut top bearing
    By jas98 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2010, 08:06 PM
  2. Strut Bearing....Advice?
    By gee38l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2008, 09:47 PM
  3. VB front strut top bearing
    By 9C1pack in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-05-2006, 11:24 AM
  4. how to replace tail shaft bearing
    By crouchy69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2006, 05:39 PM
  5. How do you replace the distributor bearing?
    By Holdfast in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-10-2005, 08:39 PM
