Results 1 to 2 of 2
Thread: problem
    xex 343 Guest
    Default problem
    off and on for the last two months, when trying to start vp calais. While turnng the ignition over the engine trns over but then cuts out.
    (if i pump the accelerator, it will keep reving until i take my foot off)
    If i keep turning it over without reving, after the sixth try it will barely idle at about 500 revs, and then the revs build up to about 800.
    Any suggestions. Please help............
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by xex 343
    do i diagnostic on it....sounds like it maybe MAP sensor,crank angle sensor IAC valve....
  1. Amp problem
    By Gunns VC in forum Car Audio
    Last Post: 16-10-2007, 03:33 AM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. Sub Or Amp problem???
    By calais_cruzin in forum Car Audio
    Last Post: 17-01-2007, 01:44 PM
  4. Another Problem
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2006, 01:03 PM
  5. Problem after problem!!!!!
    By Swerve103 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2005, 06:24 PM
