Results 1 to 9 of 9
Thread: Antenna stuck
    VQ Caprice
    Feb 2006
    Default Antenna stuck
    the antenna doesn't want to go back down. Its just stuck. any suggestions greatly appreciated. (its electronic so did'nt want to force it down).
    Cheers,
    VP WAGON V6
    Mar 2006
    li have no idea but i have an elec antenna laying around if you wanna replace it.. make an offer
    DJ Majah's Avatar
    DJ Majah is offline Electro doof doof styleé
    VSII cruiser
    Jan 2004
    Brisbane - Ipswich
    How long has it been stuck for? A while ago mine didnt want to go down, so I left it and the next day it worked fine. I think it did that twice over a few days and hasnt since.
    Queensland - The Cruising State
    VQ Caprice
    Feb 2006
    Thanks for the offer. I never use the antenna, it just looks like a fuc**** stupid.
    I'll see what I could do. Keep the offer open.
    Cheers mate
    VQ Caprice
    Feb 2006
    It happened on Saturday. Tried like you the next day, and the next; still the same. I'll trie to push it down lightly and press the button.
    Does your antenna go automatically up at start up and immediately backup down? Cause mine does.
    Cheers,
    pauleee Guest
    can you hear the antenna motor going? if you can then it could be that the mast cable has broken... its a common problem.
    VQ Caprice
    Feb 2006
    pauleee Guest
    fuse for the antenna, and the connecting wires to the antenna - check that there is power going to the antenna.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Its probably your module. I've had to replace my module once now the new one is stuffed as well. Originally the module was stuck on down so when i press the button to make the aerial go up, it comes straight back down. Now it wont go down except when i turn the radio off. What you can do is override the module and then the antenna goes up when u turn the radio on, and down when u turn the radio off. The module is located behind the kick panel, but its up quite high near the glovebox.
  1. im stuck what to do next?
    By calais_304 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2007, 10:45 AM
  2. CD Stuck
    By VZCalZone in forum Car Audio
    Last Post: 26-04-2006, 11:48 PM
  3. still stuck in the 70s help me
    By mutant in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2006, 08:59 PM
  4. What Ya Got Stuck On Ya Car
    By soulyouth in forum The Pub
    Last Post: 04-08-2005, 09:21 AM
  5. Stuck?????
    By liquidforce_134 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2004, 07:48 PM
