Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: blown reverse gear.. fixing
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    Default blown reverse gear.. fixing
    hey guys, just blew my reverse gear in my manual. its a vn..
    now i dont know what exactly happened but now wen i put it in reverse it moves like 3 cm's then there is this massive clunk which jolts the car... what is happeneing here?
    i was told around 1500 to fix it.. bull shit!!!!! so im gonna do it my self.
    now what i need to know is how to check it all out, how do i check reverse in it with out taking it all apart like splitting it, isnt there a back plate or something, also im gonna need pics ect.
    another thing is if any one has a blown manual box with working reverse gear. cause ill buy it off u...
    thanks ur friendly and very upset commy driver
    check my ride
    http://forums.justcommodores.com.au/...ad.php?t=16665
    and feel free to comment
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    come on guys, some one must have interior pics of a manual box or even a book with the plans of the interior.
    or even a blown up one sitting around that has working reverse
    check my ride
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by VN-88
    now this massive clunk in reverse does it lock the car up,or just a clunk?what happens if you keep reversing? my first suggestion is to check universal joints,gearbox mount..if you suspect reverse is shot,not a 100% diagnosis,but it will tell you something is a miss in there,undo the gearbox oil level bung(top bung),see if the bung has any metal or shavings,etc stuck to the back of it,as it is magnatised.otherwise to check reverse gear,i'm afraid it's gearbox out ....won't take long just undo the 4 bolts holding gearbox on to bellhousing,no special tool required as 12mm ring or socket will undo them..(12 mm from memory) but first off remember tail shaft out first,mark tailshaft take out the 4 bolts,undo the 2 bolts that are holding the centrebearing(the bolts that look like they are going thru the floorpan) from memory it's the outside bolt X2...1 either side..1/2 hour job to remove....also have to remove gear lever trim panel to get lever off.....
    take top cover of and have a look down in there,see what you see,i can't post pics,don't own a scanner anymore,and i don't have any gearbox jobs on the go at the moment to take pics of..
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    um i havent really left it in reverse for too long, it moves back about a inch maybe less, then clunks, i only let the clutch out a little and as soon as its a certain distance out it clunks so i just push it back, cause im scared of maybe it worse, but its a huge clunk.
    and by taking that top bolt thing of for the oil level if there is metal in there then its not good hey...
    do u have any blown boxes at your house or work that has a working reverse. ill check it this weekend and see wats going on.
    check my ride
    Hairy Eater's Avatar
    Hairy Eater is offline Banned
    2000 VX Executive V6
    Nov 2005
    Queensland
    VN-88... i'll wait for your next reply here... i have a VN Gregory's... if you need help, just ask here... messege me or email me...
    Sep 2005
    yes if theres metal shavings on the bung...actually either top or bottom,they are both magnatised...it's just that the bottom one is obviously your drain plug,if you suspect reverse is shot,empty gear oil into clean container,you will definately see if theres something a miss in there,oil will be greyish colour/metal shavings mixed with it.
    sorry no i don't have any boxes laying around ....rare as hens teeth here
    i have a 5 spd wagon,but i'm selling the car complete,i'm just doing finishing touches now, bloody hinge gave way on me and popped a hole in windscreen...
    so the clunk is definately coming from gearbox? just try and reverse it further and see what happens...noises,etc,etc..
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    i would keep reversing but m scared, its a hard clunk and the whole car jolts, like almost jumps, and im afraid of doing something alot worse
    check my ride
    Sep 2005
    with out actually sitting in the car,and listening to the actual noise and trying it in reverse,it's hard to give you a definitive answer,but the way you are describing,it may only just be something simple like uni joints or even centre bearing......does it make clunking noises in forward gears? could also be backlash in your diff...unless previous owner knew that gearbox was on it's way out,as it shouldn't have given up the ghost on you that quick....unless you have given it a bit of stick,to see what you've got now power wise
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    well it doesnt make any noise in forward, as ive been driving it abit now and its fine in every other gear. so i cant see it as unis or anything else other then reverse, im gonna change the oil tonight and see if there is metal in there
    check my ride
    Sep 2005
    OK...let me know what you find.....the uni joints may have more movement in them going backwards,as your putting reverse pressure on them,anyhows you'll let me know either way
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    ok so i just change oil and i cannot see any metal, i had 1 psec in the whole thing, a ting 1/4 * 1/4 mill spec, and the oil may have been sparkly but really it didnt look like it had any sparkly crap at all. no huge chunks... But i did have my car up on larg rams and maybe a huge chunk sat at the back, with the tail chaft, i took it back off and went back wards, it went maybe a foot or half and clunk, dad thought it was the shaft till i did it again it it actually through it out of reverse, so dad said maybe it just seemed to sound through the tail shaft. and i think there is alittle play in my centre bearing and front uni, but nothing really and that wouldnt cause my gear box to jolt out of reverse
    check my ride
    Sep 2005
    it may be time to take box out and lift the lid....but remember,you only have to undo the 4 bolts holding it to the bellhousing.pop the lid and and look to see if anything looks out of place....I.E reverse idler..detent springs,etc.
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    ok, ill have to do that this weekend then
    fun fun fun.
    the plate i take of what one is that, is it were the selector goes down?
    check my ride
    Nov 2005
    Queensland
    just got your message... i'll scan tomorrow 6 pages and get them off to you about 4.30 to 5.00 pm.....
  15. #15
    Sep 2005
    fun fun fun.
    no it should be the plate right in front of selector plate...when you are taking off top cover take note of the location of the 2 dowel bolts
    lift it up slightly and slowly,slide the cover towards filler plug side to allow shift mechanism to clear groove in 5th/reverse shift lever
  16. #16
    Nov 2005
    Queensland
    Smile
    i scanned 10 pages and sent to your email yesterday.... let us know how things are progressing....
  17. #17
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
  18. #18
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    found the problem fellas, got some pics..
    new bottom shaft for me
    Attached Thumbnails Attached Thumbnails blown reverse gear.. fixing-26-03-06_1343.jpg   blown reverse gear.. fixing-26-03-06_1344.jpg
    check my ride
  19. #19
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
  20. #20
    Sep 2005
    Quote Originally Posted by VN Calais 5.0
    Thats pretty nasty mate, no wonder why reverse gear was making a wicked noise! I wish you luck in getting another shaft.
    shouldn't be that hard to get hold of,if you can't get it at GMH as a spare part,i'm sure Borg Warner australia could supply him with another one,even if it has to come from the states.
  21. #21
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    ok, anyone gt the number for borg warner australia. or any good wreckers, i could just get it second hand
    check my ride
  22. #22
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    hey, wat is that acutall part called, the one in my pic, its hard trying to get a price on something wen im calling it the bottom shaft and they dont no what im talking about
    check my ride
  23. #23
    VP Executive R-spec
    Jan 2005
    Do those gears come off the shaft?
    Because I found a web site in the states that sell all the gears but they don't mention any complete shaft like that
  24. #24
    Sep 2005
    it's generally called a reverse idler shaft..did you try GMH for parts? any transmission specialists in your area,they would know of a supplier,otherwise, if part can't be found, it's mechanical engineering time,to make you one up,but my guess would be,cheaper to get another s/hand box....
  25. #25
    Sep 2005
    actually i seem to be wrong about borg warner being in australia,according to their site there is no borg warner australia,so GMH must have to keep parts,as borg warner is still contracted with all the drivelines and tranmissions
    anyhows...borg warners site
    http://www.bwauto.com/media_room_global_locations.html
  1. Bulbs in Gear Selector Blown
    By dave0103 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2006, 10:42 AM
  2. Under Gear Light Blown? how do i get to it?
    By orrdogg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2006, 10:22 PM
  3. Electrical issue in reverse gear. VL
    By vlv8vic in forum Electrical Wiring / Questions
    Last Post: 22-09-2005, 04:21 PM
  4. Vh Reverse Lights Only Work In Drive Gear??
    By BoboRobbo in forum Electrical Wiring / Questions
    Last Post: 14-04-2005, 09:05 PM
  5. reverse gear
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2005, 02:13 PM
