Results 1 to 10 of 10
Thread: 3800 V6 stock turbo
    1995 VS Executive
    May 2005
    Default 3800 V6 stock turbo
    Hey all,
    i was lookin around through google at Buick V6's and i came across a turbo version of it. They put it in a few cars but the one that cought my eye was this White Pontiac trans am: http://www.gmhightechperformance.com...es/0512gm_tta/
    Does any one know anything at all about these type of motor and how they relate to the Buick V6's that power our mighty commodores. Because, and correct me if im wrong but you cant really pump alot of boost into a stock V6 without blowing head gaskets... 3 - 4 Psi if im not mistaken is the limit.
    Cheerz, Zach
    Lifes different when your sideways...
    Check out my Kustom VS: http://forums.justcommodores.com.au/...ad.php?t=30244
    VP Executive R-spec
    Jan 2005
    I've read a thread from a guy that run 18psi in a stock one long term. 10 psi seems totally safe if the engine is nice and fresh from what I've read
    Aug 2004
    yea i wouldnt go above 10psi
    they arent really the same motor simluar but not the same
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    18psi through a stock motor? I couldn't see it lasting too long term though. How the hell did he get away with that?
    Gravity is proof that nature keeps getting us down.
    VP Executive R-spec
    Jan 2005
    Vengance has also run that much boost hasn't it? apart from pistons and rod bolts (and I'm not even sure if it had those in the end) that bottom end is stock too, you have to remember there a heaps of people in the states running Buick V6's with over 1000hp and they are pretty much the same engine but with a strong crank/rods/pistons
    VN Commodore
    Feb 2006
    ya reckon one of those inlet manifolds would fit on a series 1 motor... that would be the go
    mouce's Avatar
    Jul 2005
    I thought Vengance was running at 10.5, but hey...I could be wrong on that. Mind you, I know you're right about the yanks running 1000bhp buick engines, those guys are insane.
    1995 VS Executive
    May 2005
    Quote Originally Posted by mouce
    I wouldnt mind getting one of those 1000HP v6's between my strut towers!!
    Thommo_Berlina Guest
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    another car to look at is the buick grand national or GNX, run the turbo where our powersteer res is and i think they run about 240hp stock similar to that trans am
  1. To Buy or Not To Buy?? SV 3800
    By samh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2009, 02:29 PM
  2. stock VN 5.0 vs turbo charade, 85rwkw
    By vnstu in forum General
    Last Post: 25-10-2006, 11:36 AM
  3. The 3800...
    By JacoReborn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2006, 01:25 PM
  4. 3800 fit
    By vp_s-pack in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-02-2006, 10:29 PM
  5. Confused and unsure...turbo/supercharger/stock turbo?
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 09:51 PM
