Results 1 to 10 of 10
Thread: VN seat adjuster is loose.
    VN Exec
    Oct 2004
    Langwarrin, Vic.
    Default VN seat adjuster is loose.
    My VN buckets, particularly the drivers seat, are loose in the winder mechanism. By this I mean the back of the seat winds back while driving and I am continually having to give it a wind to bring it back up into position every 5k's or so. When it's in my correct driving position, I can just push against the back of the seat and see the adjuster wind back about a half turn. Driving me friggin' insane!!!! The passenger seat does it also, but nowhere near as bad.
    Does anyone know if it's possible to tighten the mechanism up so it's not so loose? Any info appreciated. Cheers....
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    might be easier to get a new seat.
    or get some out of a vs they bolt straight in and look better
    Adam
    flyen is offline bye bye
    Feb 2006
    both my seats do this, i will look tonight and see what helps then post the info
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    I believe this is a common VN prob. My drivers seat is realy bad and my pasenger seat it a bit better. Every 5 mins i had to re-adjust the seat and i got sick of it. I tryed finding a way to tightin it but no luck so i ran out of ideas and just adjusted the seat to where i wanted it, drilled a hole through the plastic adjuster thing and into the plastic bit behind the adjuster and put a zip tie through it. Its been held with a zip tie for a year now and havnt had a prob so im happy. But if anyway know a proper way of fixing it plz tell
    Australia. Love it or leave it
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Zip tie (very good idea and cheap) would appear to be the best bet - or buy a newer seat.
    I should add that I have pulled a seat down but could not fix it.
    Apr 2006
    canberra
    Yeah i dont have the money for a new seat, well I do but id rather spend it on other parts for my car so the 2cent zip tie will have to do unless someone knows a better way to fix it proply?
    HATER VP Guest
    NORTI's Avatar
    May 2004
    cool Ill try having a look at washers, if not.... The zip tie wins!!!! lol
    Good thing that Ben & I drive in the same position - Gangsta sytlez
    Damn wreckers want waaaayyyyy tooo much for S seats
    D.
    HATER VP Guest
    Yeah thats rite. And you'l probley still end up with the same problem.
  1. Back of Passenger Seat Loose?
    By warrick in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-03-2007, 12:20 AM
  2. Height adjuster
    By Spirit in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-03-2007, 03:04 AM
  3. Seat belt height adjuster??
    By aperfectcircle in forum General
    Last Post: 28-02-2007, 08:08 PM
  4. loose seat backs
    By ben k in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-05-2006, 11:31 AM
  5. Seat Adjuster
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-11-2005, 04:24 PM
