Results 1 to 8 of 8
Thread: Interesting list of 1/4 mile times
    VP Executive R-spec
    Jan 2005
    Default Interesting list of 1/4 mile times
    http://home.iprimus.com.au/lsd265/ac...tion_times.htm
    This guys been busy testing anything he can find
    2x VS
    Jul 2005
    Hey GF...just been doing some mathematical calc's to see what my Calais should run under perfect conditions
    15.6s is what I get...compared to a VS SS...15.9s....sound right ?
    and 15.3s if my motor was in an Exec...
    For .3 of a second for luxury I'll be sticking with the Calais...
    figures based on http://www.redbookasiapacific.com/au...J&key=HOLD97BU
    and
    http://www.web-cars.com/math/calculations.html
    very intersting... I plugged the equation into my Graphic Calculator and it says I need 285 Kw to run a 13 sec pass
    Disclaimer For The Reader ::
    The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
    If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
    or do not use the information at all
    I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
    I am NOT a Mechanic. You have been warned.
    VP Executive R-spec
    Jan 2005
    The VS SS will run 15.2's (at least in the manual version) and will be a fair bit better than that these days with good tires and more radical drivers . The Supercharged 6 in a normal non calais VS was good for really low 15's like 15.1 or .2 So I'd say a Calais would be good for 15.5 or .6 so sounds fair enough to me
    2x VS
    Jul 2005
    I just recalculated according to my K&N adding approx 5 extra KW...
    just .15 difference....
    The equation suggests you have 181 KW @ FW according to your times...
    how does that compare with your G-Tech ?
    Ok my motor in a VK 170 KW = 14.4s
    VK 285 KW = 12.1s....WOOT !!! if I only just kept my VK with the 10 bolt
    VP Executive R-spec
    Jan 2005
    My VP is not making 180kw, it's just quick off the line, it doesn't gain any time on my V6 after the 100km/h believe it or not . Techinical problems, rubbing brake rotors, restrictive exhaust stuff like that, It will go much faster once I get it fixed up a bit
    Jul 2004
    Quote Originally Posted by greenfoam
    I'd like to know where you get these figures from, considering that in the VS, the Supercharged 6 was only available in Calais or Statesman.....
    VP Executive R-spec
    Jan 2005
    I've seen a stock VS Berlina with one in it with my own eyes just last year
    Jul 2004
    musn't have been stock......
  1. VY SV8 M6 1/4 mile times?
    By JMiller in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-06-2006, 12:00 AM
  2. V6 1/4 Mile Times
    By STROKEDVR6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2006, 01:15 PM
  3. 1/4 mile times for vn-vs v8
    By jdjones in forum V8 Development and Modification
    Last Post: 01-11-2005, 02:38 PM
  4. 1/4 mile times vn v8
    By vncala in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-09-2005, 02:56 PM
  5. 1/4 mile times
    By DRAGON7 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-08-2004, 12:18 AM
