Results 1 to 8 of 8
Thread: vn v6 5 speed g/box into vn 5.0l??????
    May 2005
    Default vn v6 5 speed g/box into vn 5.0l??????
    hey everybody i was just wondering if the vn v6 5 speed will fit behind a vn 5.0l motor. thanks in advance
    cheers
    Busta-P
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    im not sure but if its from a v6 and u put it in a v8 there might be a bit to much power and blow it.
    thats if it bolts on
    Adam
    Jan 2006
    stanthorpe, qld
    bonglung Guest
    It can be done but it's not worth it.
    You would need a V8 Bellhousing and a V8 input shaft as the v6 one is shorter. Not sure about the clutch fork but that might need changing.
    Plus the 8's have different gearsets. But if you're keen, change the input shaft and get another bellhousing and you're in business.
    May 2005
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    its not worth it for the head**** of having to change it a week later. Just save extra money and find a V8 one.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Wonderboy Guest
    yep listen to stealthy. or.... you could save up a chunk and get a tremec. if your planning on anything over 250kw in the future. be sure to get a decent clutch also. exedy heavy duty are an awesome bang for buck. mine was about 280 bucks i can chirp 3rd in a v6. my mates 5litre sv vn wagon can chirp 4th with the same clutch. the one up from that is a cusion button but its like 600 wing wangs, its either on or off though. either stall or wheelspin at the lights. and you cant ride them or you shag em.
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by Wonderboy
    ohhh, i never knew anyone else was in the 'chirping 4ths' club. welcome!
    my clutch is worth 1000, probably the downfall of all my gearboxes. Only thing i can recommend, get a decent clutch, but make sure its not stronger than your gearbox. $500 every 6 months is fine, but $2000 is ridiculas.
    cheers sexy
  1. 4 Speed Auto VS 6 Speed Manual?
    By Wicked_D in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2007, 02:09 PM
  2. VR V8 5 speed ute
    By brock in forum Parts And Other Items For Sale
    Last Post: 06-09-2006, 09:45 PM
  3. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    By quick202 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-10-2005, 11:12 PM
  4. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    Last Post: 05-10-2005, 11:01 PM
  5. digital speed read out in VS with speed alert
    By vs0001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 06:09 AM
