Results 1 to 12 of 12
Thread: series one 3.8 v6 auto to manual ?
    kiwigem Guest
    Default series one 3.8 v6 auto to manual ?
    hey guys i'm looking at buying a series one 3.8 v6 commy donor car for my Gemini project but the engine comes auto and i'm not sure if the manual gerbox change over is easy ? and can you use series 2 boxes? also can you super charge the series one engine with the later model commys superchargers ? whats teh difference between s1 and the s2 engine ? thanks for your time guys !
    Vn commodore
    Nov 2005
    As far as i know the series 1 can not have a manual on an auto, something to do with the crank.
    Differences are
    series 1 has thermostat at rear under throttle body, series 2 has it at the frontof the motor.
    Different coil packs.
    cant think of anymore atm.
    kiwigem Guest
    really ? the series one cant have a manual all together u mean ? i did hear something about the crank ?
    Vn commodore
    Nov 2005
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by kiwigem
    you need an adaptor,or the complete kit 'n' kaboodle series 1 motor and 5 speed box from a wreck...
    kiwigem Guest
    ok sweet so i'd need a series one crank ? is that all ? what about series 2 crrank and series two box ?
    Doctor Sodways's Avatar
    Doctor Sodways is offline Legendary Baby!
    Slammed VeeDub Rat and a Brunette...
    Sep 2005
    Behind a Camera...
    kiwigem Guest
    yeah i would buy it but i'm in new zealand too much hassle still not sure if i'm gonna buy this other engine if series 1 engines are too much work to convert whats involved i have to change the crank ? what else bell housing ?
    Sep 2005
    no ....you don't change cranks...technically you can,but it's far more easier and probably cheaper to just buy an adaptor with flywheel if you have one,or you can buy a CRS flywheel that will bolt onto your series 1 auto crank,OR swapping the lot from a 5 speed wreck..or donor car..motor and box
    kiwigem Guest
    Sep 2005
    any idea on how much these adaptors are?
    if you already have the 6 bolt flywheel,i think it's $350.00...best bet is to PM VN88 he's just finished his conversion using the adaptor,he can give you the prices....
    kiwigem Guest
    just pulled my auto box off today and yes its the 6 bolt flywheel ! but i might look at gettig a second hand s1 manual box and flywheel those csr ones aint cheap
  1. Do VN Series 2 Auto and manual have the same cranks
    By jonathanvb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2007, 07:24 PM
  2. Will a VN series 1 manual g/box fit onto VP series 2 motor?
    By VPioneer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2007, 05:27 PM
  3. WTB. Vs series 2-3 manual pedalbox
    By BFCK97 in forum Parts And Other Items For Sale
    Last Post: 26-01-2007, 08:26 PM
  4. Commodore Manual VN-VG Series *SA*
    By SlyVR in forum Parts And Other Items For Sale
    Last Post: 30-01-2006, 11:13 AM
  5. VN Series 1 manual to auto
    By Tadeusz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2004, 06:59 PM
