Results 1 to 13 of 13
Thread: Whiteline Suspension, any opinions?
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Default Whiteline Suspension, any opinions?
    So I'm driving a VN at 4wd height, with blown shocks at the moment, and I'm thinking I should do something about it.
    http://www.whiteline.com.au/YourCar/kits/CK_VL-VP6.PDF
    I'm thinking of the complete package "The Works" as whiteline call it, just the low one (not going superlow). Anyone got any pics of it fitted to a VN at the moment? I'd like to see a few shots before I spend my hard earned.
    That said, it's going to be a while before I've got $1200 to spend on it (fitting myself).
    Gravity is proof that nature keeps getting us down.
    VQII Caprice
    Mar 2005
    Newcastle
    Thumbs up
    Hi,
    I have a Whiteline works kit fitted to my VQII Caprice.
    Granted its IRS etc etc but anyway.
    The suspension is firm. Straight forward firm.
    But handling is superb. It takes a good few k's to relearn the car.
    Be gentle with it and it can turn so neatly and flat.
    The car is very predictable to drive now.
    Very happy.
    The car is not "slammed" but once i get around to putting rims on it it will be low enought.
    I have a neat 10.5mm clearance on the majority of my exhaust (lowest part)
    Here are some pics anyhow.
    Anymore q's pm or email chris@nce.net.au
    BTW have you got any quotes.
    I did install it myself but i ended up buying it from Unreal Autosports for $1.3k including a strut brace.
    vave
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    I can only speak for the VL, but I know a guy that had a very poor kit and had very poor customer service when his parts failed numerous times.
    VQII Caprice
    Mar 2005
    Newcastle
    Quote Originally Posted by Bax
    Maybe, but in my experience they had good customer service indeed.
    Btw, had the suspension fitted for around 40000 kms now
    VP Executive R-spec
    Jan 2005
    VQII Caprice
    Mar 2005
    Newcastle
    Quote Originally Posted by greenfoam
    Looks like you have an impressive garden to go with the statesman
    That Caprice to you !!! lol.
    GF's house, not mine...
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Why is it that these springs place always make the heights the same, Why don't they lower the front springs 5-10mm lower, When in gear the rear drops and it make it look like the front is up.
    My brother had his car lowered 100mm Front 95mm Rear some said to him it looks high in the rear, But once in gear was perfect height all over.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    mouce's Avatar
    Jul 2005
    It only drops the rear when you're in gear in a car with IRS. Having a live axle at the rear means that it's not really an issue.
    Well...that's how I understand it. I could be wrong.
    Doctor Sodways's Avatar
    Doctor Sodways is offline Legendary Baby!
    Slammed VeeDub Rat and a Brunette...
    Sep 2005
    Behind a Camera...
    That whiteline gear is awesome, be it that i have only seen it in a VL, but damn, i have never seen an aussie car take corners so flat and stiff. Mind you it made it an absolute bastard to change rims over with a normal jack cos there was no body roll, it was really hard to jack up. But, that whiteline gear, its commin for my car, no doubt
    VY Berlina Wagon Gen 111
    Aug 2005
    Mouse, go for the King springs option depending on how low you want to go. Cheap on e-bay or even repco. If you go too low then you'll need new struts and short travel shocks $$$$$
    LETHAL 27
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by mouce
    I always thought they all dropped a touch but more as you said in the IRS?
    My car looks funny at times with it's high front end, Both standard height rear and front but with a full tank you can't miss the front up higher. I was even thinking of getting lowered front springs to match it up
    mouce's Avatar
    Jul 2005
    With an auto the rear may squat a bit with a live axle, but not that I've ever noticed in my mates VN's (mind you their suspensions were fairly tight). Being a manual, I think that if it does drop in the rear when I grab a gear, I'm in a LOT of trouble.
    @Lethal27: I don't want to go really low, I'm not even looking at the superlow whiteline setup. From what I can work out the first stage of lowering from whiteline takes the front to about FE2 height, and lowers the rear a bit more so that it sits flat.
    Thanks for all the replies, looks like I've gotta start saving for all this gear (and a set of spring compressors ). From what you're all telling me, this IS the way to go.
    VQII Caprice
    Mar 2005
    Newcastle
    To be honest, my car did squat before this gear, but since fitting it might drop about 5mm max. It is not even noticeable anymore.
  1. Whiteline Suspension Components
    By gslrallysport in forum GSL RallySport
    Last Post: 06-03-2012, 01:46 PM
  2. Whiteline Link Pin Kit
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2006, 03:03 PM
  3. Whiteline Suspension Kits
    By mattman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2006, 12:59 AM
  4. opinions on wheels and suspension
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2006, 11:17 PM
  5. Whiteline Sus
    By Michal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2004, 03:33 PM
