When I turn the key my fuel gauge goes straight to full yet the tank is near empty. Where do I look for the problem?
Any help will be great.
Thanks.
Originally Posted by madsav
Ok I was too lazy to search
i'd say check the wiring and connection to the sender unit in the tank... the wire should connect on the sender that usually on top of the tank... theres a plate in the boot to take off so you can acces it
I can get to the sender from under the car, just behind the diff, it is a wagon.
