Results 1 to 10 of 10
Thread: Washer Pump
    VQ Caprice
    Feb 2006
    Default Washer Pump
    Hey guys,
    Bought a new washer pump to replace old one. Still doesn't work. Can't hear pump either. Don't think its fuse cause wipers work.
    Anywhere else I can look at.
    Cheers.
    YMY-88U's Avatar
    YMY-88U is offline Donating Member
    Project VH SL/E
    Jun 2005
    i need help on this aswell, when i press the wash button just the wipers turn on, so im thinkin that the pump may have rusted out. ill have to go and source another one
    VQ Caprice
    Feb 2006
    wait; so when u press the wash button the wipers come on? Is that standard in vn's adn vq's?
    YMY-88U's Avatar
    Project VH SL/E
    Jun 2005
    well when you press the wash button, shouldnt the wipers come on automatically with the wash?? when i press it, it only does about 2 wipes then turns off, so i think it is spose to come on with the wash... or maybe the relays or sumthing are screwed up
    Vp Commodore
    Dec 2005
    lol, i have the same problem to, although when i press the button the wipers dont even work either so im thinking its just got something to do with the switch itself
    VQ Caprice
    Feb 2006
    Mine use to work until a friend made a groove and put the plastic lever back on, but washer pump was still wasn't working.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    When the button is pushed the wipers are meant to operate.
    If you can't even hear the pump then there is most likely a problem with the power to the pump, start at the switch and work your way to the pump, check the earth for the pump too.
    If the wipers don't operate, check the relay for the wipers, then check the wiper motor itself, then go back and start checking the switches until you find the busted connection.
    Gravity is proof that nature keeps getting us down.
    Ygoford's Avatar
    Ygoford is offline YGOFORD?
    Vr
    Mar 2006
    i have this same problem except i tested the pump with a batterie supply and it turned on and its not a fuse cause i checked em all but somehow its losing power between the button and the pump cause they all work just not together :S
    hear anything let me know ok
    With Great Horsepower Comes Great Irresponsibility
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by mr_l_commodore
    dicky pump switch....you may have to check whole lot again,as from memory you have to replace whole pod,you can't just replace wiper switch,and they aren't cheap,but been awhile since iv'e replaced one so may have dropped in price
    VN V6 Commodore Executive....and a London bus
    Dec 2005
    I had this problem, but in my case my squirters were all clogged up, so i cleaned around the squirter opening with a pin, then put some hot, soapy water throught the system, worked great! If its the pump, then you should'nt hear it when you press the switch, vn window washer pumps make a lot of noise, just like the rest of the car! lol
  1. sump washer
    By vt_lover in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2007, 08:48 PM
  2. Washer Bottle
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-12-2006, 10:46 AM
  3. washer
    By Pauly2478 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2006, 06:25 PM
  4. VQ - VN washer pump
    By SHIFTA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2006, 10:47 PM
  5. windsreen washer
    By looneytunes0123 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2005, 09:46 AM
