Results 1 to 4 of 4
Thread: Installin Sterio AUX
    ir8prim8 Guest
    Question Installin Sterio AUX
    Hi fellas i am new to just Commodores and i am here mainly to ask if anyone here knows hoy to get into the head unit
    i had the sterio professionall installed but i brought a auxillary plug just the other day to plug my psp into it so i can watch movies or play music threw it
    any help would be greatly appreciated
    thanks alot IR8_PRIM8
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    hey,let me be the first to say welcome to the forums,
    aight so you mean to remove the headunit so that you can plug the aux in the back of it??
    did they leave you with security keys to remove the headunit??
    im assuming they used a new bracket,
    heres a guide that might be of some use(to remove the required panels of the console)
    1.pull the ash tray out next to the gear selector, pull the entire panel up, it should pop off and the gear icon panel will fly away, dont worry u can match it up later...then unplug the ciggie lighter, to get this panel out you need to drop it in drive (car off with handbrake on, if not you'll roll somewhere lol) twist it to the side and angle it up a bit and it should come out
    2. now you will have 3 screws exposed for the headunit surrounding, undo these then pull the panel out, be sure to disconnect the A/C before applying pressure (dont be affraid to use force, u probbly wont brake it and if you do go buy a new peice at the wreckers for $5 =p)
    3. now with the headunit exposed there might be 2 screws either side, un do these and remove the headunit... plug it in and slide the (be careful not to pull the temp control gauge out too far, if the control rods come loose u'll spend the next 3 hours puttin em back on
    4. plug it in and re-assemble, you said you need to run the AUX cable for the
    psp correct?... i reccomend feeding it through the inside of the panels and popping it out where the ash tray it, if you dont use it even maybe design a cover panel for it with a connecter for aux??? just throwin some ideas at ya
    hope this helps
    heres a link to another guide premmy did
    How To: Doors and centre console removal
    ir8prim8 Guest
    Talking
    thanks PaRaDoX616
    i got it installed and now have to go to the reckers and pick up an a/c button and the fan controler or watever it is
    but thanks a ton for the help and i maight chat to u later
    IR8_PRIM8
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    no problem mate =D
  1. help on new sterio
    By nathans1987 in forum Car Audio
    Last Post: 31-01-2007, 07:32 PM
  2. Abs Piece Below Sterio
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2007, 09:28 PM
  3. installin memcal getttin pissed off
    By blaze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-08-2006, 10:44 PM
  4. VZ Sterio Upgrade (UTE)
    By cikas in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-07-2006, 12:50 AM
  5. installin an lsd by changin gears
    By vnbelina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2006, 11:16 PM
