Hi, i was just after an answer to the possiblility of having a the 5.0L V8 radiator on my S1.5 3.8L VN (If they are different?). By the looks of things they have the same recovery tanks and they should bolt up no probs but would all the hoses and fittings be the same, or possibility to modify if it was needed on that issue.
Alternatively is there an aftermarket solution that will work nicely???
i think you will find the radiator hose are in different positions
But this wouldnt be a problem, New hoses that are the right length :POriginally Posted by LowVp
Would i encounter anything else besides this???
if your fan and radiator are not keepin the engine cool there is a problem else where, ever had your cooling system cleaned
