I have a VN wreck with a good windscreen and I want to remove it and install it to my VP. I was quoted $168 to do this or $270 for a new screen. I know if the VN screen breaks then I have wasted my dollars so if I can, I want to remove the screen my self to save dollars.
How hard is it to remove a windscreen from a VN?
I am looking for helpful hints for removing it.
Also helpful hints to install it back in again.
its worth paying the 250 od dollars to get a brand new one put in profesionaly ......its jus to much of a basted to change em over...and in most cases there is no garuntee u will get it out without damage....
at least if the pro does it u will kno it aint gonna leak or cave in on u at 100ks lol![]()
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
hey dude it is a mission to do, i tried to do mine but end up cracking my windscreen. You can ring places in the yellow pages that do second hand windscreens fitted with new seal and warrantied against leaks for around $250. If you take yours out you have to seal it and put a new windscreen mould in about ($75 for you to do).
im not exactly sure what the wire is called ..... but its sorta like ahhh very dull serrated wire that ya poke thru a small hole made and wrap a screw driver around each end with you on the inside and a bloke on the outside and push pull effect cut the rubber . i helped the window bloke do all the windows on our cats at work n thats how we got em out. ill try find what the wires called. was bloody easy too., thats the best way i can think to do it
$250 for a new windscreen, tell him hes dreamin, i would be ringing some other places because that is expensive! I get windscreens done in Melbourne for $140 supply & fit.
Yeh but thats Melbourne, I live in a rip off state (let me rephraise that "The Smart State") North QLD. $270 was from NOVA (you know that pretty yellow Van)Originally Posted by VN Calais 5.0
Knowing the name of the wire will be helpful.
shop around boss ....way to expensive,QLD..rip off state??,your the cheapest state arondOriginally Posted by kowan
, here in hobart a windscreen $220 fitted,unless your in the glass trade,sure you'd get at @ $ 150+ bills...althoughthe cost does rise if you get them to come to you,free if your in metropolitan type areas here,but if you have to get them to come out past their metro area they charge travelling.
it's just a wire rope..like you said serrated edges,they pierce the seal,push wire through run it along the top,down the sides,keeping even pressure on the second go whilst pushing top out..then they use like a big kitchen knife (sharp as buggeryOriginally Posted by mikevxss
...)to cut the seal on top of dash,as the seal is breaking you push on screen from inside,till she be a loose and out she is...15 minutes and it's out
Thanks everyone.
I will let you know what happens, if I break it, I break it, shit happens.
ok i just took a rear windscreen out ( its for sale).. i smashed the front one cause i was trying to use diffrent ways. What you do is get a bottle of soapy water, and spray it all over the sikerflex, then using a snap blade or flexible knife ie fish filting knife cut the rubber from the inside the car. I was told this by a professional. I managed to crack the front one by using a steak knife so dont do that lol. Then i hit the other side with a hammer to see how much force it took to brake. I couldnt brake it
lol
Just be really carefull and take your time.
I am going to wait for the midday heat before I do it and yes I will be taking my time in doing it.
God i musta got a bargan when i put my new window in i only payed 150 for a new window plus installI was quoted $168 to do this or $270 for a new screen.
yeh its an accelerator cable well thats what i used at upullit worked sweetOriginally Posted by mikevxss
Originally Posted by yosy
Yeh great idea, I`ll try that
My cat has eyes, where did u find one with a windscreen?Originally Posted by mikevxss
Do u put ur hand up its arse to clean the screen?
If you want to break the screen you must travel at more than 5 K's over the limitOriginally Posted by commy92
Cat= Catarpiller earth moving machinaryOriginally Posted by vnberlwagon
Let me start off with...... It will not stop raining and I`m all wet and the wreak is in the rain with no diff nor front wheels.
I tried wire, that broke. (I`m excited)
I tried cable wire (throttle cable), that was bloody useless.
I tried a long thin kitchen knife, that was ok until it got blunt (wife aint gunna like that).
I tried a snap blade, that was great, I was cruising, it was cutting it like if I was cutting into butter.
Now for a slight problem (NO, I did not break the window), the snap blade is not long enough to slide behind the dash to reach the lower seal, OH BUGGAR!!
Is it possible to buy a longer snap blade?
I got a new screen for $150 a couple of years ago into a VP! Supply & Install!Originally Posted by kowan
Reaper
did you try asking at a hardware store for the cutting wire?... i just got the idea now.... try guitar wire or piano wire....
Hairy Eater, My son wont let me use his guitar strings.
I found a long thin fishing knife I will try it in the morning.
They must make the windscreens in Melbourne then freight them to North QLD and charge $150 in freight.
Like I said before I got quoted by NOVA $270 for a new screen + fitting
fuch shipping a windscreen, just get a beer, a pen, a notepad and the yellow pages, sit down, write out all thre places that do windscreen, the ring everone of them up and ask them a price, the finish the beer take a shit, then get your arse down to the right shop and wella, cheapest around
*note, taking a shit is not compolsuary
ok I got the window out, useing a sharp long thin knife and soapy water, lotz of soapy water. That was a great tip.
Now I phoned the only two windscreen places here in town and got prices to pull the old cracked screen out and replace this window I have spent a few hours removing.
First place: $140 which can be done in 6 days
Second place: $138 can be done on Tuesday.
I would remove the old screen myself but I have no shed to put the car in if it rains.
Thats life.
