Results 1 to 9 of 9
Thread: Tailshaft.... vibrations then noises
    VN Calais 5.0L
    Feb 2006
    Default Tailshaft.... vibrations then noises
    Hi all.... i have a vn calais v8, and it has had the usual tailshaft vibrations when i accelerate hard off the mark, but yesterday the tail shaft (i presume) started making a noise like a jackhammer, and its only when accelerating.... so it may be a mount???
    Has anyone ese had this problem? what should i check and look for???
    Thanks guys
    SlowVac is offline Owner of a SlowVactioner
    VN SII
    Mar 2005
    Possibly the uni worn out or the the counter weights are missing on the tailshaft.
    Check if the tailshaft is loose/play.
    missus (in more ways than one)
    Sep 2005
    check the botls on the centre bearing, adn the bots from the uni to the diff, then see if it has ecsessive play
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    i had to replace my centre bearing as it was making a funky noise when i accelerated.....sounded more like a ticking sound tho not a jackhammer
    VP WAGON V6
    Mar 2006
    Sep 2005
    oh come to think of it, the muffler just before the diff, somtimes it comes off the rubber and when you turn a corner or go over a bump it bashes against the uni bolts at the diff, makes a **** of a noise, i got some mig wire a tied mine up so it cant miove
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Sounds like my right now but it only did a miny jackhammer once hard take off, Unbalanced feel and all, My centre bearing needs replacing rebalanced etc but my uni are fine, If your in Vic go to the place i did MS Driveshafts McIntyre rd North Sunshine.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    VN Calais 5.0L
    Feb 2006
    Turns out the unis and centre barings are fine, but whoever replaced the centre bearings didnt do it right..... i was also told it may be slightly out of balance....
    The mechanic said it would be cheaper to find a good tailshaft from the wrecker and just replace the whole lot....
    $120 for the shaft, $100 to fit..... this sounds reasonable to me.... how about you guys????
    VY Ex-cop
    Mar 2006
    Quote Originally Posted by daves8
    $100 to fit it?? thats a load of crap, it takes a whole whopping 15 maybe 20 minutes to replace a tail shaft on a hoist. there would be no way i would pay $100 to get that done, do it yourself.
  1. bad vibrations
    By gladi in forum General
    Last Post: 23-07-2006, 06:55 PM
  2. Vibrations!!!
    By RevHead1313 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2006, 11:20 PM
  3. Bad Vibrations.
    By 253@7k in forum Car Audio
    Last Post: 14-06-2006, 11:41 PM
  4. VibrationS!!!
    By Bob129 in forum Car Audio
    Last Post: 29-01-2005, 09:42 PM
  5. Vibrations
    By tr3nt in forum Car Audio
    Last Post: 29-01-2004, 06:54 PM
