Ever since I had my wagon the rear lip of the bonnet has always rubbed against the wiper arms when raising bonnet.
How do I fix this problem?![]()
simply loosen the two bolts either side...on the hinges(that bolt to the body) and pull forward,if you adjust the ones on the bonnet,you may be able to get a forward pull,but they are more to adjust the height of your bonnet(rear height)...it's a wonder you haven't cracked your windscreen yet in that situation..your wiper arm isn't bent?Originally Posted by vnberlwagon
I had the same problem with my passenger wiperarm, however the problem was the wipermotor had broken in two places where the screws secure it to the wiper mechanism thingy. Not saying that this is your problem but could possibly be.
I found it easier to take of the wiper arm then replace it a couple of ml higher it took about 15 mins . it's just trial and error till you get it right
