+ Reply to Thread
Results 1 to 3 of 3
Thread: series 2 vq with series 2 vn motor, almost stalls between park and reverse and drive
    sp001in's Avatar
    sp001in is offline vyma100 sp001in Berlina
    MALOO R6
    Jul 2005
    QLD
    Default series 2 vq with series 2 vn motor, almost stalls between park and reverse and drive
    idle is perfect majority of the time. except occasionally revs rise and fall a bout 400rpm, but air fuel gauge remains constant. other times is perfect. hot or cold have no affect on it occurring.
    when start. go from park to neutral, gearbox big clunk, car almost stalls. to neutral fine, to drive and bang. think stall convertor isn't disengaging properly or something. also other night in the city in low ratio drive. put my foot down at the lights and it sounded like the diff slipped, metallic grinding noise but has been ok since.
    when driving a 65k's and go back into 2nd loud metallic clank comes from diff area.
    when driving if i back off, slam the accelerator, back off same sound is produced.
    diff is brand spanking new lsd. diff has been removed and checked they are unable to duplicate fault.
    Is it universal joints, gearbox, torque convertor???? at a total loss?
    vnexecutive wagon
    Mar 2006
    try the centre bearing also when checking leave car in neutral but pull hand brake on as leaving in gear can put load on centre bearing taking away the backlash if it is stuffed
    VS commodore
    Apr 2011
    umina beach,nsw
    hows the tailshaft ends? have you being doing tranny stalls at all? ( reving it off its tits and then slaming it in drive or gear 1
+ Reply to Thread
  1. Vr series 1 and series 2 is their a differance int the motor???
    By Raven_2656 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2007, 01:26 AM
  2. WTB: VN series 2 to VR V6 motor
    By The Darkness in forum Swap / Wanted to Buy / Trade
    Last Post: 18-04-2007, 07:34 PM
  3. Vn Series 2 Motor vs Vr Series 1
    By fitzy2005 in forum V6 Development And Modification
    Last Post: 23-03-2007, 07:45 PM
  4. Will a VN series 1 manual g/box fit onto VP series 2 motor?
    By VPioneer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2007, 05:27 PM
  5. strong joilt when put into drive from park or reverse
    By cruzn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2007, 09:45 PM
