Results 1 to 4 of 4
Thread: Cable on Throttle Body
    S Pack's Avatar
    S Pack is offline Topped out @ 230kph
    Mercedes E-Class 2007, E220 CDI Wagon
    Jul 2005
    Germany, Europe
    Default Cable on Throttle Body
    Can anyone tell me about the adjustments made to the gearbox cable on the throttle body(series 1). I know how to adjust it but which way has what effect on the gear shifting. You can make the black stopper thingy look longer or have it pushed in shorter. Something to do with the kickdown maybe.
    YMY-88U's Avatar
    YMY-88U is offline Donating Member
    Project VH SL/E
    Jun 2005
    i adjusted my kickdown cable ages ago cos it was taking too long and revving to high to shift into 2nd gear. cant remember which way i adjusted it though... it may have been to the drivers side but i cant remeber
    ScottB_33's Avatar
    ScottB_33 is offline Go Hard or Go Home
    VTII Berlina Supercharged
    Oct 2005
    Nowra
    To reset the cable back to standard, to be able to adjust for your liking. Just push the button in on the side of the mounting and pull the cable back out away from the throttle body. Next release the button and turn the top of the butterfly manually with your hand as though you are openning the throttle all the way to full throttle. You should hear the kickdown cable ratchet back to the correct original default position. Once the cable is back to the factory setting you can then adjust to suit (ie. closer to the passengers side will give a smoother slower change, while closer out toward the drivers side usually means a firmer harsher change) Hope this helps!!!
    S Pack's Avatar
    Jul 2005
    Germany, Europe
    Well ive moved the black thingy out further (towards passenger side) and the result is easier kickback but it doesnt like holding the gear at high revs and a slight smoother shift
  1. Broken throttle cable thread
    By Joes_meat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2009, 04:01 PM
  2. Throttle cable installing
    By sexcvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2009, 03:57 PM
  3. Throttle Cable
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2006, 10:02 PM
  4. Throttle Cable
    By Gobbles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2006, 06:45 PM
  5. Kick down cable too tight - restricting full throttle; HELP!
    By vq~gangsta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2005, 05:33 PM
