+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 51
Thread: Anyone cured a 5 liter of a drinking problem?
    VP Executive R-spec
    Jan 2005
    Default Anyone cured a 5 liter of a drinking problem?
    I can't get less than 14l per 100ks 100% highway driving no matter what I do on my VP, The cars running fine, runs strong but the fuel just vanishes! before my eyes : ) even with a grandma right foot. Any ideas for me? I'm willing to replace every part that could be causing the problem
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects..... Blown V6 Hatch W427 Blown V6 Hatch W427 Blown V6 Hatch W427
    VN Calais 5.0, UC Torana L67, WB Ute EFI 5.0
    Jun 2005
    Cowes, Phillip Island
    14l per 100? Wow thats a lot, on a long run my calais gets around 10l per 100. I get around 13l per 100 around town.
    Boonz's Avatar
    Boonz is offline the holden mechanic Boonz Maloo Boonz Maloo
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    clean your injectors and check your sensors.... check your o2 sensor and idle air control valve first though..... mine averages 10 on the highway
    '00 WH V6
    Dec 2005
    wouldn't have anything to do with your custom memcals? :P
    Driving a CURSED WH V6.
    Boonz's Avatar
    Jul 2005
    noooo way having a tuned memcal is actually making your fuel economy better by far...
    VP Executive R-spec
    Jan 2005
    Yup I know I should be seeing about 10 on the highway but I'm not, and it's very anoying , I've replaced the 02 sensor = zero difference, replaced the fuel filter, replaced the dizzy cap, rotor button zero zero difference
    Boonz's Avatar
    Jul 2005
    clean and reset your IAC valve and clean your coolant temp sensor, maf sensor and TPS settings
    '00 WH V6
    Dec 2005
    Quote Originally Posted by boona15
    Depends on what it is tuned for......
    2x VS
    Jul 2005
    Yep they do that when they get tired...my Vk developed a drinking problem after many years of hard driving....re-ring time !
    Disclaimer For The Reader ::
    The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
    If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
    or do not use the information at all
    I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
    I am NOT a Mechanic. You have been warned.
    Boonz's Avatar
    Jul 2005
    within reason yes.... like keeping it stock but changing the ignition timing and duration does help the fuel economy...
    unless your like hozy and have a chip thats designed for 103 octane
    ZERO fuel economy lol
    VP Executive R-spec
    Jan 2005
    OK Boss, I've never had an error code on the ECU either, shows all a OK, IAC maybe suspect but can that make the fuel consumption change? the car has stalled on me a couple of times. I might order a new air sensor, sometimes a bit weird with the car it's allways needed more throttle to hold 100km/h than my V6 did, I've cured that a bit with a better tune but it's still not up to the V6's few millimeters throttle to cruise on 100 standards. Needs like at least 1cm maybe more on the V8
    Boonz's Avatar
    Jul 2005
    just ahve a fiddle, i spent a week straight getting all of my sensors working correctly and keeping the o2 sensor happy lol
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by sixshooter
    Not so sure the motor is tired? it can still rip a sticky 225 to smoke leaving a corner and still be spinning in 2nd gear at 90km/h, it makes no weird noises, idles smooth and uses no oil. One weird thing it does, it that it starts very fast when cold but turns over fairly slow when warm
    Boonz's Avatar
    Jul 2005
  15. #15
    VP Executive R-spec
    Jan 2005
    Yeah, with a die grinder
    But apart from that, no not yet, it's not really dirty at all but I will pull the throttle body apart on the weekend and clean the IAC and investigate the TPS sensor, the throttle body is due for a shaft cutting and a bit more smoothing anyway
  16. #16
    Boonz's Avatar
    Jul 2005
    haha thats a better idea than what i was gonna say
    but yeah the throttle position sensor needs to be correct to get the most out of your fuel economy because it could be telling your computer porkies about how much air is going into the manifold
  17. #17
    VP Executive R-spec
    Jan 2005
    Boona do you think rubbing brake rotors could make that much difference? because I do have a rotor or two that bind when you turn them, but it doesn't feel so bad with the wheel on when you give it a spin. I just wonder if something like that is stopping the car performing like it should, like it's .8 of a second quicker to 60mph than my VN right, and .8 seconds quicker over the 1/4 mile which means it gains NOTHING on the v6 from 100 to 140
  18. #18
    Boonz's Avatar
    Jul 2005
    lol machine them if anything....have you got an exhaust on the VP yet??? could be why it isnt getting top end as well as it should,
  19. #19
    TAILS83's Avatar
    TAILS83 is offline alcoholics go to meetings TAILS83 Executive
    VPII Club Sport, Build NO# 339.
    Sep 2003
    Brisbane northside
    are u going off what the dash says as an average, as around town i get about 14-20lt/100km then when i go on the hiway know i am barely using 9lt/100 but the dash still says 13-17km/km's if i don't reset it.
    could be anything tho, a blocked cat, broken sesor thats not showing up as a fault or even just the injectors need a flush. i drive my car hard and i still get about 350-450 km's out of an 80lt tank around town.
    Never late, in a 30..4 lol
  20. #20
    Boonz's Avatar
    Jul 2005
    also highway driving is affected by your tyre pressures and load distribution and stuff, wheel alignment and wind resistance
    lots of things to think about really,,
  21. #21
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by TAILS83
    Nah I don't have any level 3 dash tech but I can put 40 liters in it drive to work and back for 3 days and be out of fuel, works out to be about 14l/100, I was grannying around the whole time except once this morning I got bored and when I saw a kangaroo and fog free area I wound her out down a back road till the wind was whistling pretty goood (must have been a windy morning, unusual with fog hey)
  22. #22
    Boonz's Avatar
    Jul 2005
    see what it averages when your driving liek you normally do greenfoam....
    ill do some figures on mine and tell u how much mine uses!
  23. #23
    VP V8 Calais
    Nov 2004
    Hey Foamy,
    Replacing sensors gets to be expensive once you start doing a few. Since V8s & V6s use the same sensors, I'd recommend just swapping them with your V6. Just swap 1 at a time and see if it gets any better.
    Also, is your TCC locking up?
    Good Luck.
    CATCH!
  24. #24
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan pandaman Caprice
    VN Berlina 5.0 A4
    Feb 2006
    Hmm, ok how about engine health basics? Compression test on each cylinder amd check valve lift to make sure you don't have one or more cylinders sitting there drinking fuel and producing bugger all. That make any sense or am I too drunk for my own good? Also with your custom tune, have you messed around with the fuel map at all?
  25. #25
    Full Spectrum's Avatar
    Full Spectrum is offline Apply In Circular Motion Full Spectrum Calais
    2000 VT II Berlina V6
    Dec 2003
    MARS
    Quote Originally Posted by greenfoam
    Well you know how my VP was getting bad economy like you VN, It still does 260-300, But on the freeway to camperdown i was doing at best guess about 10-11L on the freeways,
    But for you, you should be able to run 9L on freeways,
    Call me dumb but what about you last diff gear on freeways, When i drive to me it sounds like a 5 speed when the diff hits top @ 85kp/h what if your isn't and the revs stay up? How are your revs @ 100kp/h myn sits on 1700rpm @ 100.
    Quote Originally Posted by Decicrate View Post
    Maybe the police were simply adjusting the lads antenna.
    What could be better, you get pulled over for doing a skid, the police offer a free adjustment, a couple of good whacks later, the reception is far clearer then ever before.
    Nothing like a bit of good old community service.
    Hell I used to love giving my TV a kicking when the picture went fuzzy, always worked a treat!
    please note, the above was said with sarcasm in mind.
    The above statement may or may not represent the authors view on said subject
    VT II Berlina V6
+ Reply to Thread
  1. My 1999 VT SS 5 Liter V8
    By DMONEYX3 in forum VT - VX - VU - WH - V2
    Last Post: 06-01-2008, 04:01 PM
  2. Simulating the 5 liter
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-07-2006, 12:17 AM
  3. VS Manual to VN Auto 5 liter
    By Mst_Wtd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2006, 01:06 PM
  4. Cured ....
    By ElDubya in forum Jokes/Humour
    Last Post: 16-01-2006, 03:45 PM
