Results 1 to 13 of 13
Thread: Hand break level is JAMMED!!!!!!!
    Vn Commodore
    Jul 2005
    Default Hand break level is JAMMED!!!!!!!
    oh no this sux, im starting to hate my car more and more everyday lol.
    Ok what happend was i went to put the handbreak down, but the button was stuck! i pushed really hard and ended up getting it half way down, then it jammed! then i pushed the button more and now the button is pushed into the barrell thing and i cant get to it.
    the hand break is about half way down though, i drove home with it like that....any ideas on how to fix this? i need the car for work!
    General
    Car - 1991 Vn Commodore
    Wheels - 17" Roxbury Liquid Chrome / 235/45/17 Kuhmo's
    Audio
    Deck - Pioneer DEH-P675OMP
    Splits - Alpine TypeS 170A
    6x9's - Kicker K-Series K693
    Subwoofer - 1x 12" Directed Audio (Xtreme) Model : 212D
    Amp - 2 Channel Singer
    Amp #2 - JL AUDIO - e1200 Monoblock[/COLOR]
    Mods
    K&n air Pod
    Lukey Exhaust From Cat Back
    Sc14 Super Charger!
    Autoteknica Blow of valve
    Speco 2" Boost guage
    Video!
    http://www.youtube.com/watch?v=ZYhZFnY2Vwc
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    ive never heard of that happening before. your gonna have to pull the lever off and have a look at the button mechanism. it must be jammed with something sticky or something.
    gocommygo Guest
    ok, this happened to me before, you gotta take off the panel near thats around the gear knob and unzip the leather thing near the handbrake and get sum wd-40, innox, etc and spray the button and keep moving the lever up and down and play round with it till it works, thats what i did to mine and havent had probs since.
    kowan's Avatar
    kowan is offline Clayton's Commodore
    91 Clayton's Commodore/Toyota Lexcen
    Sep 2005
    Far North QLD
    Sometimes when your eating your KFC or putting you fingers where the sun don't shine and you go to release the handbrake, you put all that crap around the release button and it gets jammed. Under that button is a long spring which pushes forwards but if too much crap gets in it then you have no way of it releasing.
    http://aussiewholesalers.com now closed When I growup I`m gunna buy a real car
    SV3800
    Jan 2006
    Not just the handle moving up the shaft? Try pushing the rubber handle bit back down see if the button comes out more...
    VN Wagon
    Feb 2005
    The rubber button swelled on our car and jammed the handbrake. You can just pull the button off and replace it from Holden (~$5)
    kowan's Avatar
    Sep 2005
    Far North QLD
    The only way I could fix mine was to replace the brake handle.
    To do this, make life easy, put your car on ramps, remove the left front seat and console. Having them removed, you can see the two bolts. Now under the car you remove the handbrake cable, two nuts.
    xlr8_87's Avatar
    xlr8_87 is offline No longer a commy driver
    '96 Prado 4x4
    Mar 2006
    Melb, VIC
    had the same problem, mentioned it to my mechanic when i took it in for a service, he replaced the button and all has been good since
    <<<Rob>>>
    Ecotec VP, 135rwkw, 427nm
    VN
    Jan 2007
    Quote Originally Posted by kowan View Post
    I need to replace my brake handle too. Can you give any more details? Where are the 2 bolts?
    cheers,
    David.
    vr statesmen
    Jun 2009
    mm i hate this....it jus happened to my vr statesmen n itz reli annoying!! my cuzin put my handbreak up high i went to put it down this mornin and it got stuck half way... now it is stuck
    Vp series 2
    Jun 2008
    after you take the console out you will see 2 bolt down beside the passenger seat, they old the handbrake lever in.
    VP Commodore
    Feb 2008
    Leda, WA
    i have a similar problem, the button "fell" into the handle so i pulled the cover and boot off. the button was just lying on the bottom not connected to anything, as in there is no bar, cable until the bottom of the handle just above the spring??? i dont have a manual so can anyone help?
    philip_rawoz@yahoo.com.au
    RawOz Photography, specialising in nature and motorsports.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Best bet is get ahold of the Gregory's Manual.. Im fairly sure it will have that in there on how to dis-assemble & replace
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
  1. level 2 tacho into level 3 dash
    By andynogo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2008, 05:34 PM
  2. Level 1 dash cluster to level 3
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2006, 06:28 PM
  3. Replacing level 2 cluster with level 3.
    By madmick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 11:18 PM
  4. VS Level 1 to Level 3 Cluster Upgrade
    By Luv holdens guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2006, 01:28 PM
  5. break pads? price? vt break conversion?
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-09-2005, 06:02 PM
