Results 1 to 9 of 9
Thread: severely pissed off with my vn
    ProMaX's Avatar
    ProMaX is offline Make way!
    04 VZ SS Impulse Blue Ute
    Aug 2005
    Bella Vista, Sydney
    Angry severely pissed off with my vn
    ok, after 3 weeks of my vn being out of service and off the road i've given up trying to fix my car with an auto electrician friend of mine. 2 mechanics, 2 auto electricians and myself as well as all my mates are completely dumbfounded by whats wrong with my vn (1 mechanic and 1 auto electrician haven't seen my car personally but have been explained everything as well as all questions answered) ANYWAYS
    firstly does anyone have a wiring diagram for the Vn commodore like from battery > main fuses > fuses under steering wheel etc
    My car doesn't work electrically, mechanically it's fine, the fuses under the steering wheel dont have any power going thru them except for the battery fuses, the ignition ones and the ones label A,B,C,D dont have any power going thru them and the other category which i forgot what it's called.
    Also, the fuses in the engine bay have no power going thru them either, no fuses have been blown, and the main fuse (just above the battery) that has a 60amp on it doesn't have power either :/ and i dont have an alarm or central locking or immobilizer... we were wondering if there is a stock immobilizer of some sort that would do this?
    I have no hazard, no parking/reverse lamps, indicators, wipers etc etc
    Any help would be much appreciated and i'd be forever grateful
    I'm sorry if i haven't explained properly or written incoherent as i'm blinded by frustration and would gladly clear anything up/answer any questions that may help u understand my nonsense better
    Thanks in Advance
    Never Forget You're Unique... Just Like Everyone Else
    I'd Rather Roar Than Whistle
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    by the sounds of it, pretty much every fuse has no power, id be checking wiring in the engine bay, around the fuse box area especially. dont know how the autoelecs cant find the problem.
    goto your local library, they should have a grwegories manual you can photocopy, or buy one.
    ps, dont double post, it wont really help, jsu tpisses people off.
    ScottB_33's Avatar
    ScottB_33 is offline Go Hard or Go Home
    VTII Berlina Supercharged
    Oct 2005
    Nowra
    That type of problem you would have to take to a professional to repair as obviously it is not a run of the mill problem and a professional will e able to find it quicker and cheaper than you spending whats sounds like has been weeks trying to find a problem. Thats why they are professionals in their trade!!
    ProMaX's Avatar
    Aug 2005
    Bella Vista, Sydney
    ok so new update.. the auto electrician has found that there's a bad connection from the battery to earth and has gotten the lights to work, but also there maybe be a problem with the starter motor, either the relay or the starter motor itself... two questions
    How much is it to buy a new starter motor?
    and
    Does anyone have a wiring diagram for the VN 89 model SI?
    cheers, thanks in advance
    Hairy Eater's Avatar
    Hairy Eater is offline Banned
    2000 VX Executive V6
    Nov 2005
    Queensland
    does this scan help you ?... let me kow if you need more...
    Attached Thumbnails Attached Thumbnails severely pissed off with my vn-vn-wiring-1.jpg
    Aug 2004
    ProMaX's Avatar
    Aug 2005
    Bella Vista, Sydney
    Cheers hairy eater ur a champion
    Cracker: where can i buy those? as in brand new or just go wreckers?
    thanks for your posts guys
    mat_rulz Guest
    hey my mate Lance has a similar problem with his vn it stuffed up about 2 weeks ago on saturday. the only thing he hasnt changed yet is the wiring to the motor. he changed the crank sensor, the coil pack, the computer, the coil pack modulator and the wire coming from the battery to teh altinator . the starter motor to buy new could cost you about $300-$500.
    dobbie Guest
    mate buy a vl
  1. pissed off with my vn
    By ProMaX in forum Electrical Wiring / Questions
    Last Post: 03-04-2006, 09:04 PM
  2. im pissed
    By WILD VR CLUBBY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2005, 09:13 PM
  3. pissed off
    By bigazza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2005, 10:02 PM
  4. Pissed Off..
    By ozute in forum General
    Last Post: 18-08-2005, 11:35 PM
