Results 1 to 9 of 9
Thread: vn 1988 series 1 auto, valve clearance for tappet adjustment
    Mattyg Guest
    Default vn 1988 series 1 auto, valve clearance for tappet adjustment
    Hey,
    I want to adjust my tappets. 1988 vn series 1 V6 auto
    Is it with the engine hot or cold?
    intake = tappet clearance? tho or mm both preferable
    exhaust = " "
    have gap guages and rocker gaskets all ready to go. should be all i need to do the operation?
    thanks,
    Matt
    VY SS Wagon
    Mar 2006
    Can't adjust them and don't need to! They have hydraulic lifters which self adjust so to speak. If anyone says you can don't take anymore advice from them.
    Hairy Eater's Avatar
    Hairy Eater is offline Banned
    2000 VX Executive V6
    Nov 2005
    Queensland
    noah_73.... sometimes cam lobes or the face of the tappet wears and they wont adjust fully and make tapping noise... you can unbolt the mounting block and grind some off the bottom.... the is a cheat way some car yards do..
    Frd_thmsn Guest
    Quote Originally Posted by Hairy Eater
    I don't understand where they would grind, don't forget the lifters in these
    motors have a roller on them and don't look like normal tappets. I would hate to be grinding a roller.
    VY SS Wagon
    Mar 2006
    Strictly speaking they don't have tappets, they have rockers. And why on earth would you want to do something so butcherous to what is probably a perfectly good engine is beyond me. On top of that it is good way to introduce metal contamination to your engine, no amount of covering oil drain ports is going to stop it.
    Apr 2005
    Did this with a friends 202 engine when we put a regrind cam in-stopped it rattling like a deisel. just ground the bridges down a bit to take up the slop in the drivetrain. Dodgy, but it did the job...
    Does the V6 have the same sort of setup?
    VY SS Wagon
    Mar 2006
    Very similar but it changed in the VR I think it was, if not definitely the VS. More of a roller rocker type set up.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Grinding them is a bit severe . i'd use a file
    Frd_thmsn Guest
    There's a bit of confusion in this thread as to what a tappet is.
    A tappet a.k.a lifter, cam follower, hydraulic lifter is the small cylindrical object that rides over the cam lobes inside the engine . In the VN /VP and probably later models this has a roller on the bottom that rolls around the cam lobes.
    You do not want to grind this roller.In flat face tappets there is no roller just the face of the lifter rides on the cam lobe.
    The arms at the top that you see when looking inside the rocker cover is a rocker that connects between the valve and the pushrod, this is called the rocker or rocker arm, this is the bit that some have ground.
    You may have heard of solid lifters, these are tappets that are not hydraulically pumped up by oil, their main use is in high revving engines to prevent pump up , where the lifter can keep the valve open.Earlier engines had solid lifters and it was necessary in these to adjust them with a clearance. Overhead cams where there is no lifter and the rocker arm rides directly on the cam also needed adjustment.
    The disadvantage of the roller lifters as used in the commodore engines is the weak point at the pin axle for the roller , especially when stronger valve springs are used.
    The early holdens all had flat faced tappets , the VN and probably later had roller faced tappets.
    Attached Thumbnails Attached Thumbnails vn 1988 series 1 auto, valve clearance for tappet adjustment-rt-690.gif   vn 1988 series 1 auto, valve clearance for tappet adjustment-555-hcr.gif
  1. Auto Trans Valve Body - How Do I Replace It?
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2011, 04:14 PM
  2. Valve guides or valve stem rubbers?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-09-2007, 12:05 PM
  3. Berlina VY II stereo, how do i turn off auto tone adjustment?
    By Acehoilo in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-05-2007, 01:57 PM
  4. oil leaking from tappet gasket...
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 10:33 AM
  5. vn series 2 1988 swap or sell
    By Commodore_Chick in forum Swap / Wanted to Buy / Trade
    Last Post: 31-07-2005, 09:27 PM
