Results 1 to 9 of 9
Thread: I Cant Open My Bonnet HELLLLLLLLLP!!!!
    S Pack's Avatar
    S Pack is offline Topped out @ 230kph
    Mercedes E-Class 2007, E220 CDI Wagon
    Jul 2005
    Germany, Europe
    Default I Cant Open My Bonnet HELLLLLLLLLP!!!!
    I opened my bonnet the other day and the cable broke and has fallen way under the dash i cant get to it.....is there anyway else to open the bonnet ive just replaced a radiator hose and more may go in the next week or two so i dont want to be stuck
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Is there anyway you can get up through behind the front bar to pull the lever back to pop the bonnet?
    Yours Kindly,
    Jim
    S Pack's Avatar
    Jul 2005
    Germany, Europe
    i tried pulling the lever under the bonnet but it is still closed where the cable pulls away the latch in the centre....i cant get my front kit off either cause i screwed it on in the middle at front of bonnet when open....my fingers just fit between kit and bonnet.
    there is a metal pin/wire thingy that i can see underneath and it moves when you pull bonnet cable(i know this cause i thought i was f^&ked when my lever broke and i was trying to open-i just use pliers and pull wire from dash but now broke more) would that help at all .... serves me right for not fixing sooner
    michaelw's Avatar
    michaelw is offline Donating Member
    VX S2
    May 2005
    Newcastle NSW
    S Pack's Avatar
    Jul 2005
    Germany, Europe
    Thanks i will try to find this striker thingy which i think is wat i saw moving while underneath when someone pulled the lever when working
    S Pack's Avatar
    Jul 2005
    Germany, Europe
    ok ive worked out how to open it now is it easy to put a new one in DIY should i be getting a new one or one from the wreckers
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    id just say one form the wreckers, but i dont no how much a new would go for, might be same price for a new one but i some how doubt it
    check my ride
    http://forums.justcommodores.com.au/...ad.php?t=16665
    and feel free to comment
    S Pack's Avatar
    Jul 2005
    Germany, Europe
    bought cable today $16.99 from Aussie auto went to a mech and he said you got to buy an original one cause the original one takes about 1hr and the universal one takes about 3 hours.Anyway im pretty pissed off with mechanics at the moment so i said ill do it myself. took me as long as it takes to duct tape the new to the old then pulled it straight through (about 2min) all up it took 1.5hr cause i had to find a drill and charge it to put a few extra brackets in for support.Saved myself over $150 and got more confidence at fixing stuff myself.Also got new window squirters while i was at it
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by S Pack
    If none of the other suggestions work, I have a 9" grinder you are welcome to borrow.
    Reaper
  1. need help! bonnet latch is broken and cannot open bonnet!
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2012, 11:10 AM
  2. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  3. I can't open the Bonnet
    By baryscommodore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2009, 08:42 PM
  4. Help getting bonnet open
    By obsessed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 09:11 AM
  5. My bonnet doesn't open, at all!
    By str8up in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2005, 07:25 PM
