Results 1 to 20 of 20
Thread: vn s pack is it worth it
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    Default vn s pack is it worth it
    hey guys just a quick question, i can get my hands ona vn s pack notr registerd but roadworthy is $250 a good price
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    shit yeah.....
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    thanx for that man , now im deffinatly not lettin it go, hey can u tell me is the s pack stand for sports pack , does it have many diffrences from the executive?
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I got my VP for $1700 and was over the moon That's good.
    I think the S just have modified suspension but thats all i know of it maybe different seats L2 dash badges stripes etc?.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    Aug 2004
    S.E. Melb
    interior is the same as SS
    light above ingition barrel
    v8 brakes
    colour coded bumpers/grill with pinstriping
    FE2 suspension
    tacho dash (level 2)
    rear speakers (usually)
    -dave
    fabz's Avatar
    fabz is offline I Can Do Science Me
    Blown V6 VT commodore 5 speed
    Jul 2005
    In My Car!!
    Wanna see it? give ya $500 for it ha ha sounds like a bargin but i would check its not stolen first
    .:Blown VT V6, DAJ37:.
    AE86, VE2 SSV M6 UTE
    May 2004
    Quote Originally Posted by geta
    v8 brakes
    FE2 suspension
    -dave
    Executives have the light above the ignition barrel (they mostly burn out). As for v8 brakes, why would you need them on a stock 3.8L? I mean, my vx s has the same brakes as the executive. Why would they de-spec the commodores after a vn :P.
    If i remember correctly they only had fe2 spec suspension,different hubcaps, painted bumpers, lv2 dash, ss style fabric (i dont think front seats were the same) and as you said usually rear speakers.
    '00 WH V6
    Dec 2005
    I think any roadworthy car for $250 would be an alright deal :P
    Driving a CURSED WH V6.
    Aug 2004
    S.E. Melb
    They do have V8 brakes, holden "de-specced" them after Vn cos they are tight? I dunno, ask someone who worked there at the time.
    Front seats are the same as SS
    -dave
    VY SS
    May 2005
    SA
    Yeah they do have the v8 brakes, front seats were same as SS up until 1990 model SS, that had prtoduing sections of front and back seats (similar to calais) but some material.
    Cheers, Gaz
    VP Executive R-spec
    Jan 2005
    The brakes are alot better than the V6 ones too , In this day and age when VNs are so cheap you should never never need to buy one without the FE2 suspension/brake pack on it because there's a few of them out there and it makes the car so much better
    Jul 2004
    -dave
    Holden didn;t "de-spec" them after the VN, they upgraded the base model to have the finned calipers as well....I'm pretty sure (not 100%) they are the same as VL Turbo brakes...
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is online now Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Absolutely correct there shamus.There was no such thing as v6 & v8 brakes on vp and later models as they came standard with what were previously known as the v8 brakes in the vn. VN V8 brakes are identical to VL turbo!
    Nikkojoe, VT commodores and up run 298mm rotors and twin piston calipers on all models, so there is no de spec there they just brought the lower spec models up to the same level of brakes as the higher spec models.
  15. #15
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by VN Calais 5.0
    I think the change came with the VP series II?
  16. #16
    Jun 2005
  17. #17
    May 2004
    I know VT's and up run twin pistons with bigger rotors, that's why you get the brake upgrade kits off ebay to suit older commodores pre vt right? I was saying that comparing my VX S to a VX executive, they are exactly the same.
    As for de-spec'ing, i meant that if earlier model base cars had their brakes changed to the early v8 spec ones, then the s pack has no real "improvement" in braking performance over a standard executive. IE, you are taking out the edge that the S had over the exec (it has lost the "performance brakes" term, and technically has been de-spec'ed)
  18. #18
    VP Executive R-spec
    Jan 2005
    Just had a look in the DBA book and greenfoam you are correct, 1992 was the change. Is that vp series 2?
    Yes I think October 1992? My VP must be a series 2 because it was built late in the year but I have no idea what changed in the series 2
  19. #19
    S Pack's Avatar
    S Pack is offline Topped out @ 230kph
    Mercedes E-Class 2007, E220 CDI Wagon
    Jul 2005
    Germany, Europe
    thats a good price if nothing serious is wrong with it. I got mine for $1700 with full kit, mags, and suspension but it had a few minors wrong, and i thought i got mine cheap!!!
  20. #20
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    s pack
    souns like a good buy , mine had a few thing rong with it like bonnet cable door trim and roof lining the paint is a bit sad but it is mechanically A1.
    thanx all for your replies
    vks, chris
  1. VB SLE 310 pack
    By VB_308 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-05-2012, 08:06 AM
  2. 95' VS S Pack - Should i?
    By shredR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2005, 10:51 AM
  3. My new VB SL/E 310 Pack
    By Jimbo6443 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-09-2005, 06:15 PM
  4. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
  5. Need Tip To Fix VS S-Pack.
    By s_blanker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2005, 07:28 PM
