Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Oil change
    VNV6Wagon Guest
    Question Oil change
    how do i change the oil in my 1990 vn.Any tips or hints would be helpfull.THANKS.
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    make sure u got an oil filter, 5lts of oil, and a oil tray. remove the oil sump plug, only one plug on the sump, let oil drain, take oil filter off, then install new filter, put the sump plug back in (tight) then fill, some people buy a oil filter wrench, but i cant see the point in em :P
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    If possible, jack up the drivers side of the car, just drains a bit more crud out. Also, get the oil warmed up a bit, just helps it come out a bit quicker, and with a bit more junk too.
    When it comes to filling, just dump 3ltrs in it straight up, and add the fourth litre slowly, checking the level as it goes in. Some VN's take 4.5 ltrs of oil, some only take 3.5.
    Gravity is proof that nature keeps getting us down.
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by VNV6Wagon
    buy penzoil
    Cheers.
    * RVN 355 *
    kowan's Avatar
    kowan is offline Clayton's Commodore
    91 Clayton's Commodore/Toyota Lexcen
    Sep 2005
    Far North QLD
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    How to Change the Oil in a VT/VX
    Shounak
    Always Right
    My Ride
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    May 2004
    "some people buy a oil filter wrench, but i cant see the point in em :P"
    Its called a screwdriver
    mouce's Avatar
    Jul 2005
    at the risk of starting an oil war here: Penzoil is good oil, but I prefer Penrite
    May 2004
    VY S2 Berlina
    Jul 2005
    lol here it starts :P, the question was
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    i get an oil filter there only like $5 or less and i get like $15 oil buying expensive oil wont make a noticable differance if u change it every 10,000ks like me(if i got $50 oil i would only change it every 40,000 ks or somehting like that) to me 4 changes is better that 1 change with good oil.
    mouce's Avatar
    Jul 2005
    Quote Originally Posted by fitzy2005
    We're just making sure that the poor guy puts good oil into his car. Unlike someone I do know of who actually put cooking oil in there. needless to say her engine didn't run too well for too much longer
    10 VE SSV,03 VY Exec, 83 Wb Statesman
    Aug 2005
    Quote Originally Posted by nathans1987
    :my: dam dude people ussually say every 5 thousand k's for the ecotec at least and your saying 40 thousand kms !!! but i guess 10,000 isnt to bad
  15. #15
    Feb 2004
    NSW, Australia
    Umm I wouldn't care how good the oil was, like you still get carbon introduced into your oil, so I wouldn't go much past 8,000kms.
    Yours Kindly,
    Jim
  16. #16
    Feb 2004
    NSW, Australia
    Quote Originally Posted by mouce
    :my:
    No comment.
    Yours Kindly,
    Jim
  17. #17
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by kowan
    yahhhhhhhh Penzoil "The Best Oil"
    good bloke go PENZOIL!!!!!!!!!!!!!!!!!!!!!!
    Cheers.
    * RVN 355 *
  18. #18
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    I have to disagree here. It is very important to use quality oils of the correct grade for the engine. Oil changes are the best preventitave maintanance you can do for a car or any engine. Why would you sell yourself short? Your seals and bearings are designed for specific viscocitys of oil for sealing, cleaning, and lubrication as well as cooling. Most cheap oils are only 20w50 or 20w40 mineral based types. All commodores after the VL should run a multigrade semi synthetic oil these days. You don't need to spend an arm and a leg, but if you love your car then feed it good blood. I have to recommend Valvoline XLD Engine Armour 15w40. Always been a big fan of Valvoline, except in aircraft engines because it's STUPIDLY expensive, and the Shell stuff is the same.
    As for filters, well I used to work at repco, and I can say with conviction i'd never use a cheapie. The repco/ryco/fram/valvoline ones are all good.
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
  19. #19
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Nothing wrong with Castrol GTX2.
    Another good reason to not buy a Oil filter wrench, Cause i did and it don't fit it it's to big one size fits all???. My hand fits it
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  20. #20
    Vs_sharlene's Avatar
    Vs_sharlene is offline Beats a Kick in the Face!
    VSII Executive
    Dec 2005
    Thumbs up
    Quote Originally Posted by SlickHolden
    Amen.
    5.5 Litres at super cheap for $25? Can't go wrong!! Good stuff too!!
  21. #21
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by Vs_sharlene
    Amen.
    Keep you eyes open for specials at K-Marts they once had it for $20 and i grabbed it fast.
  22. #22
    VY Berlina
    May 2005
    I'm thinking of giving this a go at the weekend, what's the safest way to secure the car when doing this? Should I get a trolley jack or an axle stand?
    Paddy
  23. #23
    Shounak's Avatar
    Apr 2005
    If you're VN is stock, don't bother.. You s hould be able to crawl under..
    Shounak
    Always Right
    My Ride
  24. #24
    VY Berlina
    May 2005
    Yeah just a stock vn thanks.
    For other work what is the safest way to go?
  25. #25
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by paddyj
    Paddy
    I get under my VP and I'm a big fella. I used the tyre brass to off the plug.
  1. want to change cas but
    By lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2007, 07:50 PM
  2. Oil Change/filter change interval on VTII 6 cyl ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2006, 04:26 PM
  3. Oil Change
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2006, 08:27 PM
  4. Name change?
    By VYSS346 in forum Site Feedback / Site Problems
    Last Post: 25-12-2005, 11:41 PM
  5. How do I change oil?
    By charteredaccountant in forum General
    Last Post: 21-12-2004, 07:20 PM
