Quik question bout the rubber mounts that hold the zost up
mine keep melting and dieing, i got my zost system done not long ago and ive gorn through about 8, ive gotta replace them once a week and im geting pissed off.
SOOOOO is there a diffrent type of rubber mount i can use? maybe one that wont melt as fast? maybe a HSV one or something.
Thnx Scot.
i've really got no idea how the hell they are melting, unless you use latex ones or somehting? mine use to slip off after i put a lukey system in, i just used some low tensile fencing wire from bunnings to secure it. worked a treat
CBR954RR
XR400R
dont knock riceburners, they are fast and reliable...
rare and endanged 94 VR auto white sedan
I like your username!Originally Posted by iwishmyVNwouldstart
ok...coupla questions, are you possitive they are "melting" and not just breaking?..because it would have to be incredibly hot to melt an exhaust mount.
also which mount is it? the one on the tail pipe?
if it is the one holding the tail pipe and it keeps breaking, most likely its the centre mount up near the cat thats gone and all the weight of the exhaust is being put on the tail pipe mount, thus it keeps breaking.
nope there melting for sure i can see it were the rubber is melted hardcore
its melting on the 8 shape ones at back ner the zost tip, though it seems to only be melting on the Bottom of the 8
i have a 3"dual tip on back, im gunna try and take a picture with my phone an post it illl reply in soon
something is wrong with your setup then...the mounts shouldnt get that much heat to them that they'll melt.
the mounts your talkin about are the tail pipe mounts i mentioned, so what i said before still stands, you centre mount is probably busted....
